How To: Make your own fresh air headlight cover!
Old May 4, 2004 | 06:37 PM
Black91n/a's Avatar
Here's how you can make your own fresh air headlight cover for less than half the cost of buying one from Mariah, RX-7.com or another commercial source. With all the materials, you'll probably have spent less than $50. Don't worry, it's not hard, but take your time and make something you can be proud of! I just made one myself, and it turned out really well. Just go to an auto wrecker and get a spare cover and get the following: fibreglass cloth and resin, disposable paint brushes, some foam, a can of bondo, some spray paint and primer, sandpaper, waxed paper, and a sharp knife. Carve the foam block until it's the shape you want. Make sure it'll fit by taping it to the cover and putting the lights up and down a few times and check the foam for damage (to get around this problem I made a raised scoop, instead of a sunken in duct and as far as I know I'm the first one to do it that way). Then put it on the cover where it'll be when done, cover it in waxed paper and fibreglass it using the disposable brushes (practice first). Once it's dry cut off the excess, sand it down, strip the spare headlight cover to bare metal and cut the hole in the spare cover (make the hole small, then slowly enlarge it until it fits, it’s much harder to add metal). Use the resin and some scrap cloth to secure it to the cover and then bondo, prime and paint it. I used Duplicolor spray paint and it turned out with a surprisingly shiny surface. There you go, you've got a new intake for a fraction of the cost of a commercial one and it'll be unique!
Old May 4, 2004 | 06:45 PM
Novacaine's Avatar
got any pics?
Old May 4, 2004 | 07:18 PM
den's Avatar
den
I'm in the middle of making one at the moment aswell. instead of using fibreglass i bought a small universal ricer vent, cut the shape out of the spare headlight cover to match and fixed it in place. I started sanding with a 600 grit wet&dry and then a 1200, you cannot see or feel the join at all now. After one coat of primer its looking quite good but is going to need more fine sanding before painting. I know people generally feel that this mod does nothing to help cold air to get into the engine, i just thought it would be a good little project to do and like Black91n/a says it makes the car unique.
Old May 4, 2004 | 07:23 PM
Ronac's Avatar
Any pictures?
Old May 4, 2004 | 07:37 PM
Digi7ech's Avatar
I break Diff mounts
Since I dented my headlight cover putting my engine in I am planning on doing something like this.
Not very hard. I could probably even make a template to produce them in FG.
Hmm. Maybe I'll pull it off tonight and make a mold to mess with. I have nothing else to do if I can't test run the engine.
Old May 4, 2004 | 08:30 PM
den's Avatar
den
during sanding :
One coat of primer :
Test fitting :
Old May 4, 2004 | 09:27 PM
emac's Avatar
wow, that looks awesome. Nice job. I'll have to try that.
Old May 4, 2004 | 09:36 PM
uRizen's Avatar
XBL** Ownicus
That's pretty cool. Do you have a pic of it painting in a matching color?
Old May 4, 2004 | 09:54 PM
West TX RX-7's Avatar
Da Monee Pit
Dood that looks great! How did you fasten/attach the ricer vent to the metal cover?
A air vent headlight cover combined with the air box below should work well together.
Old May 4, 2004 | 10:00 PM
87racer's Avatar
Where did you get that ricer vent?
Old May 4, 2004 | 10:01 PM
Ronac's Avatar
Look on ebay...
Old May 4, 2004 | 10:02 PM
dubrc's Avatar
have you read any of this thread?
Old May 4, 2004 | 10:06 PM
87racer's Avatar
What I meant was where did he get the plastic part from? Not the completed product. I realize he molded them together(kinda obvious via pictures). You missread. I was indescriptive.
Old May 4, 2004 | 10:23 PM
domesttuner's Avatar
CVPI rules the road
where did you get the airbox from?
Old May 4, 2004 | 10:38 PM
dubrc's Avatar
sorry man, Im just bitter tonite
--Paul
Old May 4, 2004 | 10:40 PM
mr_vaughn's Avatar
Chillin
www.mariahmotorsports.com
i got the headlight inlet and the air box and the KN on my turbo and it has a noticable difference to me.
Old May 4, 2004 | 10:41 PM
87racer's Avatar
Not a problem... we all have those days.
Old May 5, 2004 | 09:49 AM
rxcyprus7's Avatar
looks good man. nice write up.
Old May 5, 2004 | 12:13 PM
Black91n/a's Avatar
I've got some pics of mine, but the file size is huge and I don't have any photo shop software. I'll see if I can pick some up today for cheap, and post some pics later on today.
Has anyone ever seen a raised scoop? I'd like to know if I'm the first to do so, because that'd be so cool to be the first and to have it be unlike any other one out there!
Old May 5, 2004 | 12:27 PM
IDIGATIT's Avatar
N/A SPEED DREAMIN
looks good nice fab job
Old May 5, 2004 | 12:34 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
Can we please have the dimensions of the opening of the vent/inlet?
I hope this is and a cold air box are not your answer to getting cool air to your engine. There is more you will have to do to get this to benefit your car.
Old May 5, 2004 | 01:15 PM
Project84's Avatar
Open up! Search Warrant!
Nice fab work. And I love a DYI attitude. However, I read on here that the headlights are in a low pressure area and don't supply a lot of air. The person who posted that supposedly saw a diagram of some of the wind tunnel test done on the car.
Old May 5, 2004 | 01:19 PM
87racer's Avatar
Even if it is in a low pressure area, it has to let more air in than having no vent at all right? Plus it's not something you see every day.
Old May 5, 2004 | 07:15 PM
ViperDude152's Avatar
Rotary Power Information
it looks good. but one problem....VERY small hole. That may put some cold air in . but I would try making the whole much bigger then it is. luckily your not getting the air oil from that cover otherwise you would be starving the engine from air.
Nice work tho. I might do somthing similar to my headlight cover. you gave me the idea. Bravo
Justin
Old May 5, 2004 | 07:55 PM
Madrx7racer's Avatar
Would it not work better if you did it on the hood? Like 5 inches higher than where this inlet is? I would think it would bw more direct.
