ACV-R v.s. S-AFC
Old Nov 4, 2001 | 09:47 PM
Ridge Tech's Avatar
Question ACV-R v.s. S-AFC
I've got an '87 TII with streetporting, intake, downpipe, and highflow cat. I've been hitting fuel cut for a wile now, so its time to take action. Which would you guys recomend I get? A fuel computer or a boost controler?
As a side note, I read some where the stock computer does pretty well, something like it can handle up to 300hp or something like that. I want to be able to safely boost above fuel cut with out running lean.
Chris
Old Nov 4, 2001 | 09:50 PM
Turbo Timmy's Avatar
Professional Lurker
s-afc does not remove fuel cut. You need an FCD or an upgraded ECU for that.
Old Nov 4, 2001 | 10:11 PM
Brian_TII's Avatar
Re: ACV-R v.s. S-AFC
Chris
Neither of them will help with your fuel cut issue.
The AVC-R is a boost controller, which is good if you want to run MORE boost than you currently run.
The S-AFC is a device that allows you to alter the signal from your mass airflow sensor... which will allow you to add fuel.
You will need an FCD or ECU to get rid of the fuel cut, however once you get rid of the fuel cut you will need something to richen up your mixture... in which case you might want to get an S-AFC, upgraded injectors... etc... (depending how much you are trying to run)
Take care,
Old Nov 4, 2001 | 10:20 PM
Ridge Tech's Avatar
my understanding was that the ACV-R had the abilty to act as a FCD? Am I wrong in my understanding?
Old Nov 4, 2001 | 10:46 PM
fc3s.org's Avatar
OG
The AVC-R is just a boost comtroller, the best one int he world in my opinion, but alas, just a boost controller
Old Nov 5, 2001 | 08:18 AM
Ridge Tech's Avatar
so which would give me more bang for my buck, a home made FCD and Boost controller, or FCD & fuel computer?
Bambam7
23
Apr 27, 2002 09:04 PM
tommytsunami
Super AFC
Feb 21, 2002 02:11 AM
Rotary Rx7 T2
Feb 2, 2002 06:15 PM
Kelimutu
Jan 17, 2002 04:32 AM
AlixxxilA
Dec 24, 2001 08:50 PM
