Need to know rear end ratios of different 2nd gens.
Old Nov 4, 2001 | 05:59 PM
BogusFile's Avatar
Question Need to know rear end ratios of different 2nd gens.
I need to know because I want more top end.
Old Nov 4, 2001 | 06:17 PM
Blake's Avatar
Re: Need to know rear end ratios of different 2nd gens.
I'm confused. What do you mean by this? Top end speed? Are you hitting redline in 5th, or something? That's nucking futs. If you mean top end power, then you're just high. Changing gear ratios won't give you any power. Going to a lower (numerically higher) ratio will give you better accelleration and lower gas mileage, while theoretically impacting the top speed the vehicle is capable of achieving if it had the power. That's a big if.
To answer your question, most 2nd gens had the 4.1 final drive ratio. Automatics and early 'verts had 3.909 gears. And only the GTU-S got the preferable 4.3 gears. You can even get 4.88 gears for a 1st gen, but you have to get a real good welder to extend the pinion shaft.
Old Nov 4, 2001 | 07:12 PM
HAILERS's Avatar
HAILERS
This should answer your base question http://www.mazdatrix.com/g5.htm
Th0m4s
Feb 26, 2019 02:04 AM
mustanghammer
Race Car Tech
28
Nov 22, 2015 07:10 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
