will supra rims fit a FD?
Old May 1, 2004 | 04:51 PM
MR_Rick's Avatar
Planning my come back
I got a chance to get some RPO1 rims (I love this rims). They are 18 x 9.5 or x 9 not sure yet and 18 x 10. the off set is what I'm wondering about.
Old May 1, 2004 | 06:48 PM
maxcooper's Avatar
WWFSMD
Well, since those aren't stock Supra wheels, you will need to find out the offset of the the wheels you are considering.
I can tell you that the bolt pattern is the same on the Supra as it is on an FD. The centerbore diameter on the Supra is smaller, but you can run stock Supra wheels on the FD if you enlarge the centerbore on the stock Supra wheels.
The fact that you can run stock Supra wheels on the FD means the offset of those aftermarket wheels might be okay for the FD, but you really need to find out what they are before anyone can tell you yea or nea with any degree of certainty.
-Max
Old May 2, 2004 | 09:54 PM
3isacharm's Avatar
Car>woman
the stock supra wheels will fit with a small spacer to compensate for the centerbore problem; they simply won't fit onto the lug nuts without interference. a spacer is probably a cheaper solution, but either one would work.
Old May 3, 2004 | 12:35 AM
tt2323's Avatar
Import Connoisseur
I don't think the rpo1 came in 18x10, i had them on my supra actually 18x9.5 back 18x9 front
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
