What type of Cold Air intake should i get?
Old Apr 30, 2004 | 08:52 AM
sobelik's Avatar
The Lounge Is My Home
I just bought a 88 GTU with aftermarket exaust but i want to put in a cold air intake. which brand(s) are best for his model rx-7?
Old Apr 30, 2004 | 08:57 AM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
Thre are only two REAL CAI's on the market. Check point makes one and I also have developed one but production is slowed. If you want to check it out go to www.aztechrotary.com for the other one just search on google. I forgot the URL.
Santiago
Old Apr 30, 2004 | 09:01 AM
From: Clearwater, Largo, St.pete, Wesley Chapel, Florida, USA
Currently there are no aftermarket vendors that offer a cold air induction for our types of cars. However there are several... simple intake kits that you may purchase and "build" (tools providing) a cold air box...
I personally have cut some of the radiator support on the passenger side of the engine bay, and ran a hardpipe from my TB inlet down to the front of the radiator where my air filter currently sits.
Running a microtech i no longer have to worry about the silly silver box (AFM). It generally alot easier to run the air filter anywhere you prefer when you dont have to worry about the AFM getting in the way.
Check Rx-7.com ; Mariah motorsports sells a NICE cold air box ; Mazdatrix sells an intake kit ; and there are a few others that offer intake filters / AFM adapters but i can't think of them off the top of my head.
Maybe others could fill in?
EDIT::: HOW IN THE HECK COULD I FORGET... Get in touch with Santiago, i've heard their intake set up works well also..
Good luck..
Old Apr 30, 2004 | 09:09 AM
sobelik's Avatar
that sounds good whats this gonna run me doller wise?
Old Apr 30, 2004 | 10:17 AM
3RotorRocket's Avatar
go to his site and look
Old Apr 30, 2004 | 05:27 PM
FDreaming's Avatar
S4 now S6 soon...
K&N FIPK(filter, with adaptor for your AFM)
Mariah cold air box
Cork Sport headlight cover with NACA duct.
Boom, you've got cold air induction all day long. Then for the night, you just have to drill some holes and take out your flash to pass lense on the passenger side
Old Apr 30, 2004 | 06:18 PM
SDrotary-FC's Avatar
@ pipnorcali
vin speed make a cold air box as well
Old Apr 30, 2004 | 11:58 PM
Blade8r's Avatar
how about you do something like i did to my 7.. this setup.
in this setup i just found some pipes and i cut them accordingly to the way i wanted to fit my (CAI) (cold air intake)
here's a viedo of it.
http://ravenish.com/raven/videos/CAI2.avi
Old May 1, 2004 | 12:17 AM
Blade8r's Avatar
okay i suck i don't know how to post picture on this fourm.
Old May 1, 2004 | 12:19 AM
Blade8r's Avatar
okay i don't know how to post picture on this site.
Old May 1, 2004 | 12:23 AM
1987RX7guy's Avatar
Your AFM should be level.
Old May 4, 2004 | 09:53 AM
sobelik's Avatar
so there arnt any good kits just to go out and buy?
Old May 4, 2004 | 10:13 AM
dr.jones63's Avatar
It's a Hammer
https://www.rx7club.com/showthread.p...ht=cold+air+box
Old May 4, 2004 | 10:15 AM
dr.jones63's Avatar
It's a Hammer
https://www.rx7club.com/showthread.p...hreadid=295708
Old May 4, 2004 | 10:52 AM
im also interested in having a cold air setup. so far i think aztec has the best setup. most airboxes i have seen are just built around a cone filter which remains at the end of the stock intake tube. the box will block the heat but the location of the intake cone is confined. the only (easy) way to deliver air is to keep the stock scoop (the one on top of the radiator/fan shroud) and cut a hole in the air box for it and to remove the clear lenses. other wise drilling and ducting is required.
Old May 4, 2004 | 10:58 AM
also, i had a question which i was gonna start a new thread for but it kind of relates to this topic. ive seen plenty of intake setups and i was just wondering why people choose to keep the stock intake tube instead of getting a metal one made instead. i am planning to get one (mandrel bent and polished on the inside) made becasue it seems that the stock one has too many ridges in it that would cause air turbulence. i know that nobody makes metal intake pipes (except aztec) so they all have to be custom fabricated ($$$). so why dont people get it done? is the reason just because it costs more than the benfits it provides?
Old May 4, 2004 | 11:12 AM
cwsttu's Avatar
1.3L is not that small
thats where i come in and a few other members... i didnt think anybody did it when i posted mine but apparently the people that have done this did not post pics.... below is a pic of mine, a lot of people will argue that the metal piping will get much hotter and warm up your air.... well if you think about it it makes no sense whatsoever... first put your hand on your radiator hose DAMN thats hot... then put your hand on a metal block on the engine DAMN thats also hot... everything in the bay is hot as **** so theoretically it doesnt matter what you use... and also intercoolers (ya the things to COOL the air) use metal piping as well so apparently there is no wrong in this... just my .02 cents... heres a pic of mine after i cleaned her up...
Old May 4, 2004 | 11:13 AM
cwsttu's Avatar
also its a lot louder from the straight piping
(the ripples in the stock one act as a muffler)
Old May 4, 2004 | 11:21 AM
wow! just the information i was looking for! this forum is great. i didn't about the muffling of sound the ripples would provide. thanks alot guys. btw cwsttu, whats the thing right by your fender?
Old May 4, 2004 | 11:24 AM
also how does your car sound? how did you do your intake setup? i would truly appreciate it if you shared how you placed your filter down there. did you have to do alot of cutting?
Old May 4, 2004 | 12:09 PM
cwsttu's Avatar
what thing by my fender? in the engine bay? or in the pic in my sig.....
the car sounds mean as ****... i gutted my cats but dont have an exhaust but it sounds awesome for pretty much the stock setup.... my intake setup was really pretty easy... my car never runs anywhere near past 1/4 now heh sometimes i feel like it takes too long to warm up lol. the performance from it shocked me.. i used to have it in the bay soaking hot engine air heat before i did this and wow THIS WAS A HELL OF AN IMPROVMENT!!!
1. remove air pump muffler, washer fluid bottle and tuck away wires in that corner out of the way
2. move the pressure sensor, trim metal it bolted onto so piping does not hit it
3. get piping from a civic intake, just look on ebay and find one that can be cut to forum one straight one, and one curved one like in the pic
4. enlarge hole that washer bottle came thru at (where the piping disapears into fender) you only need to make it about 1 or so inches bigger so the 3" pipe will fit
5. bolt on filter!!
now of course this is not detailed and i do not have time to go into more detail on this post but if there are any questions just ask!!
btw not to much metal cutting, its something a normal guy can do though i used a plasma cutter at the shop i work at
EDIT: MY FAV PART ABOUT MY INTAKE ....
Old May 4, 2004 | 12:13 PM
cwsttu's Avatar
also a disclaimer i have: i used a quality K&N filter on my intake setup, i would recomend the same quality or better in a filter due to the low placing of the filter, i and many others with this setup have driven in much much rain with never one ill effect but im sure the 9$ ebay filter will prove different. be careful and choose a filter (a little more for a filter is cheaper than a new motor)
Old May 4, 2004 | 02:36 PM
jon88se's Avatar
Eat, sleep, work, mod.
I wouldn't run a cheapy filter so close to water, dust, dirt and bugs down by the grille. In addition, although I'm partial to HKS's foam filter, I wouldn't run one of these so close to the ground. Go with K&N - they are the standard, they are re-useable and you know they aren't e-bay filters Also, in order for the intake to stay relatively clean and get the correct airflow you must have the underguard for the front of the car installed otherwise air will flow under the car as opposed to through the grille. This is also important for coolant temps on hot days as you want the air flowing through the radiator and not under or around it.
Old May 4, 2004 | 02:45 PM
cwsttu's Avatar
well as you can see where the filter is is blocked off from the air around the RAD or anything over there.... i have the brake ducting providing fresh cool air for the filter... so there is no hot air anywhere near it from the motor or the car....
Old May 4, 2004 | 04:09 PM
the thing by the right wheel well. its looks like a part of the intake piping... like a sensor or something?
