uumm, I only got 4 speeds
Old Apr 28, 2004 | 03:06 PM
comeonstart's Avatar
hey been thinkg bout this for a while now that my car only has 4 speeds but i didnt read anything that disproved it, but i was reading the 100 mph top speed thread and people were talking bout 5, but i only have 4
Old Apr 28, 2004 | 03:07 PM
Hades12's Avatar
Burning Oil-Grinding 3rd
Is it a 79 or 80?
Old Apr 28, 2004 | 03:31 PM
79
Old Apr 28, 2004 | 03:40 PM
Directfreak's Avatar
I am a Jeeper Now.
Originally posted by comeonstart
79
There's your answer.
The base SA's came in 4 speed.
Old Apr 28, 2004 | 03:46 PM
Good
Old Apr 28, 2004 | 03:55 PM
What should my top-speed be then, I havent gotten it above 50 cause its not safe with my tires
Old Apr 28, 2004 | 04:50 PM
79rx's Avatar
I got my completely stock 79 sa up to 100. It matters how well the car was taken care of.
Old Apr 28, 2004 | 06:15 PM
fatboy7's Avatar
Got Boost?
The 5th gear they added to the higher trim levels is a true overdrive, the maximum speed is in 4th gear. IIRC the 4 gear boxes have the same gear ratios, they're just missing the extra gear, so you car should have the same top speed: 120 or so mph.
Old Apr 28, 2004 | 06:21 PM
peejay's Avatar
Old [Sch|F]ool
Top speed is acheived in 4th gear anyway, so it's no deal.
My car gets 23mpg city/highway whether I use 5th gear or not. Although it's a little annoying to be buzzing 4700rpm on the highway, but what the hell, it's a rotary.
fatboy has it nailed: the 4-speed and 5-speed are identical trannies, the only differences are that the 4-speed has a couple spacers to take up where 5th gear slides on on the countershaft and on the output shaft, and the 5/R shift rail only has one detent, for R (obviously). Theoretically you could convert a 4-speed to a five, but you'd need a 5-speed trans to gut, so it'd make more sense to use it if you were horny for an extra gear.
BTW - I've been driving using only 2nd, 3rd, and 4th. I might be swapping a 4-speed trans in when I get tired of hurting smoothcases, and most 4-speeds have 1st gear around 2.4-2.0:1 (about where 2nd is now) and top gear is obviously 1:1 like our 4th gears. There's no real disadvantage other than needing a little more clutch slippage after an uphill stop.
Old Apr 28, 2004 | 07:27 PM
My car doesnt like 2nd gear starts at all, I have to have a little momentum or burn the clutch off.
Old Apr 28, 2004 | 07:55 PM
Swolbynos's Avatar
Newb
did i miss something?
so i cant get a higher speed in 5th?
i can, 7500 in 4th and then i sgift to fifth and it keeps accelerating...
Old Apr 28, 2004 | 08:16 PM
Lotus00's Avatar
Mine old SP did, but I dont know about my new SE... It starts to shake really bad at around 110 (flat spots on the tires) so I havent pushed it that far yet.
Old Apr 29, 2004 | 12:28 AM
its a 4 speed with a 5th OD
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
WyomingTII
Sep 28, 2015 10:32 AM
