need a little help
Old Apr 28, 2004 | 09:00 AM
rotorysuzuki's Avatar
the rxzero
need a little help
just got my new sterling carb on and have a few ? s where do you hook up the dizzy advance to and where does the big fittng on theside between the omp lines go to thanks
Old Apr 28, 2004 | 09:34 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
The large brass fitting in the center originally contained a check valve and was used for the subzero starting assist injection. It should now be hooked to the PVC valve so that crank case nasties can escape into the carburetor.
The dizzy advance goes to the first port on the spacer (I think). I'm rusty on this because I run advanced timing as per Paul Yaw's instructions, and don't use the vacuum pot.
Old Apr 28, 2004 | 10:56 AM
Jeff20B's Avatar
Lapping = Fapping
Vacuum advance is like 7·Up; Never had it, never will.
Sterling, I like the idea of using the subzero fitting for PCV steam sucking.
Old Apr 28, 2004 | 11:48 AM
Sterling's Avatar
When you gonna buy a damn carb from me?!
Old Apr 28, 2004 | 11:57 AM
Jeff20B's Avatar
Lapping = Fapping
Who, me? Uh, after I rebuild my '73 12A of course. Streetported with '83-'85 (light) rotating assembly. I'd probably need a banana carb, right? I've got an '81-'85 Nikki I could send (it's bolted to the stupid style manifold, so that's how I know it's an FB carb hehe).
One question for you. What should I put this engine in? I don't have an RX-2, so the sky's the limit.
Old Apr 28, 2004 | 12:06 PM
the rxzero
okay another ? when I get up to the higher rpms it breaks up and carrys on what do I need to adjust that with I am now going to attempt the dlidfs hope that helps and by the way thanks sterling carb looks great
Old Apr 28, 2004 | 12:12 PM
mar3's Avatar
Administrator
How's your fuel pump? It sounds like it can't keep up now...
Time to step up to the plate...
Old Apr 28, 2004 | 12:25 PM
Sterling's Avatar
The Sterling Carb flows plenty for the 12 SP.
Put it in a '71 Opel GT, or Triumph GT6...two of my favorite sportscar shapes.
Old Apr 28, 2004 | 12:27 PM
V8kilr's Avatar
well its looks like mar3 is ready
Old Apr 28, 2004 | 12:28 PM
Sterling's Avatar
Please give me a better description, including what RPMs this is happening.
-You did upgrade the pump, correct?
What's the pressure at now?
Old Apr 28, 2004 | 12:31 PM
Sterling's Avatar
-Only a Sterling Carb is good enough to warrant such an expensive pump, I will give you that.
(...searching for smilie icon of fat head expanding & exploding...
-But then the Sterling Carb is versatile enough not to need it.
A Carter will do fine.
Old Apr 28, 2004 | 12:32 PM
the rxzero
I put in a bigger one for the holley I was running and I have it set at 3.5 it starts to carry on about 5000 rpms
Old Apr 28, 2004 | 12:39 PM
Jeff20B's Avatar
Lapping = Fapping
Those are two cars I've considered in the past. We'll see once my GLC, REPU, MG and Cosmo are road-ready.
I'll look into a Carter pump and a Holley 1-4PSI regulator for the Sterling carb. Is that correct?
Old Apr 28, 2004 | 02:14 PM
the rxzero
okay how bout this one checked the timning and both l and t are on yellow mark and I cant split them up whats that mean
Old Apr 28, 2004 | 03:45 PM
Sterling's Avatar
Sounds like you have something crossed.
