Haltech E6X on 13B NA PP????
Old Apr 26, 2004 | 07:02 PM
banzaitoyota's Avatar
What Subscription?
Anyone have any experience with this setup?
Old Apr 29, 2004 | 06:21 PM
tims's Avatar
E6K not an X. owner of car didn't want to put in the time to dial it in but it can work well. I wouldn't use anything larger than a 50mm throttle body though and make the intake manifold as short as possible.
Old Apr 30, 2004 | 12:32 AM
crispeed's Avatar
'Tuna'
Re: E6X on 13B NA PP????
With the E6k I was able to extract 304rwhp/175rwtq running on methanol fuel. Best time in a 2100lb RX-3 at 290rwhp was 10.47@126mph.
Old Apr 30, 2004 | 06:35 AM
What Subscription?
Hmm, I already purchased 55mm TB on the advice/input of the engine builder. E6X is on the way.
Old Apr 30, 2004 | 11:39 PM
crispeed's Avatar
'Tuna'
Then keep it because it will work just fine!
Old May 4, 2004 | 09:06 PM
tims's Avatar
It can work but tuning, intake, and exhaust will need to be setup correctly. Large throttle body has some weird flow issues(hard to explain). smaller throttle body seems to work better faster, but larger unit will likely make more power as it will flow more air. good luck
Old May 10, 2004 | 12:49 PM
TYSON's Avatar
WTF is wrong with it now?
Re: Re: E6X on 13B NA PP????
Do you use a metering oil pump? Or is there a 2-stroke oil out there that mixes well with alcohol?
Old May 10, 2004 | 01:16 PM
TYSON's Avatar
Ha Ha , nevermind!!
Searching Works!!!
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Robrods64
Oct 2, 2015 07:56 PM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
