Mikuni Carb size for 13B streetport
Old Apr 25, 2004 | 08:24 PM
gonzz's Avatar
Is this carb to small to run on a 13B streetport? What size is this carb?
Old Apr 25, 2004 | 09:27 PM
alien_rx7's Avatar
Interstate Chop Shop CEO
Re: Mikuni Carb size for 13B streetport
Hey gonzz, have the owner check the side of one of those barrels for the model number. That is how I figured out what size the set was that you sold to me. Alternately, the owner can take one of the velocity stacks off and use a set of calipers to take a measurement. On those 40's that I have, the opening up top was ~45mm but the Mikuni's taper and the number on the barrels said they were 40's. Hope this helps. Good luck with the project!
Old Apr 25, 2004 | 09:29 PM
Crit's Avatar
No distributor? No thanks
What are all the markings on the carb? You should see 40 PHH or something similar on it somewhere.
Old Apr 25, 2004 | 09:30 PM
alien_rx7's Avatar
Almost forgot. Somewhere on this board someone said the Mikuni PHH 44 flows 211cfm per barrel. That should help since that would be 422cfm for a single carb. Compare that to other carbs made for a streetport 13b.
Old Apr 27, 2004 | 08:32 AM
Crit's Avatar
Gonzz, you'd get a lot more for it on ebay if you did your homework. The carb and manifold should each go for what you're getting.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33550
Old Apr 27, 2004 | 01:00 PM
gonzz's Avatar
That's not mine. I was thinking of getting it
Old Apr 27, 2004 | 04:19 PM
Crit's Avatar
Sorry, just figured since you're in Vegas too... Pick it up - it's a nice carb.
