Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
HELP!!!! Revolution in 7 days and.....
Old Apr 23, 2004 | 12:31 PM
2Lucky2tha7's Avatar
Back at it again!!
Exclamation HELP!!!! Revolution in 7 days and.....
I need a timing map for a series 4/ series 5 streetported turbo II 13B that's in my brother's '79 Mariah Widebody RX7. He's running an EMS Stinger 4424 ECU (similar to Microtech, with the same direct fire ignition setup), a TO4B turbo, Cartech liquid-cooled intercooler, 760cc primary injectors and 840cc secondaries, and a few other things. We're using a Lambda for tuning the fuel map, but we have no correct timing map. The one we're using is not even close!!! If there's anyone out there with a good working ignition map from any EMS setup (preferrably Microtech), please post it or PM me!! We're taking this car up to the Rotary Revolution and there's only 7 days left!! It's a 600+ mile drive. Please help!!!
Brian
Old Apr 23, 2004 | 02:05 PM
Cosmo Donk's Avatar
Queer
Check the www.teamfc3s.org/forum and www.nopistons.com/forums Also you can join the Haltech List on Yahoo Groups and there is a file area on there. If that doesn't work you can post a message and someone should have something.
Old Apr 24, 2004 | 12:31 PM
Back at it again!!
checked both sites and they didn't have much. I actually used a Haltech ignition map that took me like an hour to convert all the #'s (kpa=psi, what each bar meant, etc.) It was the only way we got the car to run. Well, that map was wayy too basic (mostly all 36 degrees in the vacuum range---looked like a big plateau on our 3D graph). We also tried using my friends PowerFC map from his 3rd gen, but it didn't work very well at all. Anyone with a better map, or maybe even a Microtech map??
Back at it again!!
In the meantime, I'll try PM'ing a few people.
Old Apr 26, 2004 | 01:38 PM
Back at it again!!
bump
RxglassJAw
NE RX-7 Forum
Sep 10, 2015 07:35 PM
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
