Power FC Can someone explain to me what the "O2 Feedback control" function is/does?
Old Apr 22, 2004 | 12:19 PM
jpandes's Avatar
I have been experimenting with it on and off and I have noticed that with it off, it causes my idle to hunt a bit before settling down and smotting out, it also minimizes the backfiring(which is what I'm trying to fix)
So what is this thing for?
Old Apr 22, 2004 | 01:05 PM
rynberg's Avatar
John,
The O2 feedback is just the standard O2 closed-loop process for cruising conditions. Turning it on and off shouldn't affect your idle at all. I've been running with mine off for a little while as an experiment.
Your O2 sensor is probably bad.
Old Apr 22, 2004 | 01:48 PM
spyfish007's Avatar
Yellow Dragon is no more
O2 feedback is for air pump/ACV control ... I don't believe it controls closed-loop @ cruise.
Old Apr 22, 2004 | 05:57 PM
RotorJoe's Avatar
Hooray For Boobies!!!
not sure, but I though it was to try to purify the exhaust gases as best as possible.
I would think it would only work on cruise (anything besides WOT).
When I switch mine from ON to OFF, nothing happens. I may build up more carbon deposits on the rear bumper with it off, but I can't tell (car runs way too rich)
Sounds like your O2 sensor may be bad, like stated abvoe.
Goto the sensor check screen (etc.) and watch the O2 voltage.
Old Apr 22, 2004 | 06:22 PM
spyfish007's Avatar
Well lets talk about a few things here. One, do you have an air pump or ACV on the car? Two, O2 feedback that I was talking about was the following. I don't believe the setting on the PFC affects closed loop at cruise. I don't really have any proof of this, it is a feeling. I have leaned out my fuel map and got better fuel economy by doing that then with this setting either on or off, seq/non/single .... so ever!
Now back to point number one. I don't have an ACV and if I turn that setting on my car idles funny.
Old Apr 22, 2004 | 06:27 PM
spyfish007's Avatar
I checked to see if it posted and it didn't. So I hit post again and bingo ... double post!
Old Apr 23, 2004 | 05:33 AM
twokrx7's Avatar
Need more sleep
spyfish,
O2 feedback is for lean cruise. If you own a narrowband AFR sensor you will see this clearly. During cruise the AFR will bounce from rich to lean as the O2 feedback works. Turn it off and your cruise AFR will be rock steady.
I turned mine off long ago because it would go into closed loop at very low speeds and even idle. It would buck at low speeds as the motor leaned out and it would sometimes stall at stops.
Old Apr 23, 2004 | 03:27 PM
jpandes's Avatar
Originally posted by twokrx7
spyfish,
Thanks for responding guys. I am running a midpipe now and the backfring is driving me nuts. When I have the O2 feedback on, my car backfires less, but the idle bouces around and sometimes stalls at lights. My car also idles way richer according to my WB
I'm wondering if my O2 sensor is bad or if I just need to let my PFC "re-learn" my idle by doing the ALL DATA Init...
What do you guys think? Do all FD's with mid pipes backfire?
Old Apr 23, 2004 | 05:01 PM
RotorJoe's Avatar
If your O2 sensor is bad, the sensor check screen will show it to you.
Old Apr 23, 2004 | 05:06 PM
jpandes's Avatar
I have a sensor check screen? I'll have to go check that out....
Ok, I have the following things with black indicator dots next to them(I guess that means that these sensors are bad):
NTR
FPD
APR CCN
Now what?
Old Apr 23, 2004 | 10:12 PM
RotorJoe's Avatar
Look at the PFC manual in the stick at the start of the PFC forum. In there it will tell you what those mean. I thin NTR stands for Neutral. When the light is by it it means active/on.
So you were in neutral, right?
FPD may be fuel pump, do quote me on that. That should be on if the key is "on" or the car is running.
The others I can't remember right now. I can look them up, but you should probably read the manual.
The on you need to look at for your o2 sensor will be, 02S and it will have a viltage by it when the car is running and the 02 sensor has had a chance to warm up. If it reads zero with and I think a black dot that means its bad. Check the manual in the sticky.
Old Apr 24, 2004 | 04:07 PM
RotorJoe's Avatar
Don't mind all the typos. I looked at mine again and the 02 sensor just has avoltage by it, no black or clear dot. I guess if it reads zero all the time it is bad. But I am not sure, I have never had mine fail on me yet.
Old Apr 25, 2004 | 04:34 PM
rdavidsrx7's Avatar
block-spike
see rynbergs post for 100% correctnes....
that being said I turned mine off and have tuned the few cells that it was affecting....p4-p6 between n5 and n10 to run right around stoich because mine was causing my car to surge and I could watch the injector duty cycling between 12 and 16. Now it is smooth and allows much more refinement in the cells I mentioned.
Bob
Old Apr 10, 2006 | 03:10 PM
the_glass_man's Avatar
Will u do me a kindness?
So is the consensus, should it stay or should it go? I'm thinking of eliminating the stock o2 wiring from the harness. And replacing it with a full time wideband.
Old Apr 10, 2006 | 08:21 PM
twokrx7's Avatar
Need more sleep
Kill the narrowband and tune it with the wb.
Old Apr 10, 2006 | 08:39 PM
Awesome, I'll use the stock location for my EGT gauge and put the wideband right before the midpipe.
Old Apr 14, 2006 | 08:12 AM
mr.zoom's Avatar
so you could cut the wire for the factory O2 sensor, tape it and set the O2 feedback off in the pfc. put the WB sensor in the same location?
Old Apr 14, 2006 | 08:48 AM
twokrx7's Avatar
Need more sleep
Yep
Old Apr 16, 2006 | 02:42 PM
mark57's Avatar
Temple of Cornd0g
My experience with three LM-1 WBO2 units is they are all very responsive and accurate; this hasn't been the case with two AEM units. Select wisely.
Old Apr 16, 2006 | 05:32 PM
twokrx7's Avatar
Need more sleep
My AEM wb performed flawlessly ... I just hated it not displaying <11:1
Old Apr 17, 2006 | 10:21 AM
mark57's Avatar
Temple of Cornd0g
Last night I rode in a CYM with the impressive PLX M-series WBO2 gauge mounted in steering column pod; it performed superbly with excellent AFR range [incredible richness in low 10's as PFC needs serious retuning].
I shall ascertain the two customer AEM WBO2's [Reinhart Marauder and LS1 FD] get powered with clean signals and grounds and report those findings.
Old Apr 19, 2006 | 08:07 PM
NeoTuri's Avatar
The shy megalomaniac
I love my LM-1 and RPM module. It makes life a little easier.
Old Apr 22, 2006 | 03:00 AM
Aeka GSR's Avatar
oops posted in wrong forum, ignore
LongDuck
Oct 7, 2015 08:12 PM
