gforce ecu?
Old Nov 2, 2001 | 09:24 AM
Crusader_9x's Avatar
gforce ecu?
when you send your computer off to be reprogramed byu these guys what all do they do?
what kind of a horse power increase can you expect?
how far can you turn the boost up?
what do you do about fuel?
any info would be greatly appreciated
Old Nov 2, 2001 | 11:52 AM
Scott 89t2's Avatar
SOLD THE RX-7!
I'm not even sure if they are around anymore, there website has been down for a while.
but it'll retard some timming at higher boost levers (important!!) and remove fuel cut so you don't need a FCD. as well as change your fuel mapping around abit. and could higher the rpm cut off limit if you want.
you could run aboub 12psi, I'd add a bigger fuel pump with it though too.
Erosangel
Sep 18, 2015 10:28 PM
Erosangel
Sep 18, 2015 04:06 PM
