shift light install
Old Nov 2, 2001 | 01:52 AM
chaos7's Avatar
Question shift light install
I just got a shift light (traded for an intake filter). I was wondering if any of you guys have wired one in and how to do it. Oh and about the accuracy thing, what should i set the thing at 4,6, or 8. Im going to wire an adjustable resistor thing so i can just set it at where i want it.
thanks in advance
Old Nov 2, 2001 | 10:23 AM
Ryde _Or_Die's Avatar
Why get a shift light when you got a buzzer
Old Nov 2, 2001 | 10:49 AM
vaughnc's Avatar
knowledge junkie
Is it an aftermarket shift light? The OEM one that comes on some rx-7s is wired into the ECU. All it does is tell you the best time to shift for good MPG.
Old Nov 2, 2001 | 11:16 AM
Xentrix's Avatar
Kill Bear
heh, my car's too loud to hear the buzzer
Old Nov 2, 2001 | 12:54 PM
chaos7's Avatar
its an autometer. i dont really like hearing the buzzer (usualy means im low on coolant) and i got it for basically free, so i figured i'd put it in.
Old Nov 3, 2001 | 12:00 AM
chaos7's Avatar
-bump-
Old Nov 3, 2001 | 03:58 AM
chaos7's Avatar
ok so its in now. works like great. the green wire goes into this sleeve connector thing (wire with female crimp) coming off the front-bumpermost (leading?) coil wiring. set the switch in back of the light to the lowest setting (4 cylander?).
Old Nov 3, 2001 | 04:32 PM
live4boost's Avatar
AKA ShepFC3
yup when I hooked up my tach and shift light, you have to set it like a 4 banger because it fires like one.
rexone
The Bad & Fugly Businesses
Aug 23, 2015 06:24 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
