HowTo Find Correct Fuel Pressure
Old Apr 13, 2004 | 07:38 PM
CarlRx7's Avatar
ok guys/gals
my mikuni manual says 2.84 - 4.98 psi
got the 750hp OVERKILL fuel pump, reg and 1/2 feed and return line all done and installed.
i can now set the psi from 3-20 and it will stay there no matter how hard i drive.
now how do i find the correct fuel pressure i NEED to run?
more fuel pressure means?
less fuel pressure means?
the car had the stock pump, the psi was NEVER stable, going from 4psi to 1.4psi at WOT. never leaned out until it started going bad on me last week, WEIRD.
does more fuel pressure make it run richer? keep the fuel bows at the correct level better? harder onthe needle and seat?
wut are the bennifits of lower fuel pressure? dunno.
any help will be GOOD, and a 6 pack will be in the mail for the answer that solves my problem.
Carl.
Fix It Till It's BROKEN
85 12a SE Mikuni Carb All mods included!
http://home.comcast.net/~carl.bradley/
Old Apr 13, 2004 | 07:47 PM
rototiller1's Avatar
Inspector, Falcon Jet
mount a gauge in the regulator, start the car and adjust while its running
Explain your direct fire, it looks wrong or did you not remove the old leading coil, it looks like its hooked up still
Old Apr 13, 2004 | 08:20 PM
CarlRx7's Avatar
i have a gauge installed, autometer 0-15 electronic gauge.
i just never bothered to remove the "extra"coil.
Carl.
Old Apr 14, 2004 | 09:08 PM
CarlRx7's Avatar
Bumpity bump::
oh geez. this post got buried down to the 3rd page on its 2nd day of posting, and still no good answer. this must be a forum that doesn't drink.
Carl.
Rotospectre
Mar 28, 2018 03:33 PM
