Power FC Anyway to get a temp Map in order to get my car to a tuner?
Old Apr 12, 2004 | 11:29 AM
ejmack1's Avatar
Lawn Ornament
1680 Secondary Injectors
T04S turbo
stock primaries
stock ports
need to drive the car 100 miles
Would I need a Datalogit to put a map on or can I do it with the PFC commander?
Old Apr 12, 2004 | 02:02 PM
NewbernD's Avatar
Tequila? ..it's like beer
Well, you'd need a datalogit to set the injectors to 1680...
You could set them at 1500 with the commander and just have secondaries be rich. You could also bump up your fuel pressure a few pounds above stock and just run your current map if you just need to drive it one way to get tuned. Stay out of boost and you should be fine.
With no datalogit, you'd need someone to make you a mod map by doing a diff of their T04S map against the stock basemap (assuming that's what you have) and you'd be there all freaking day with commander buttons.
Old Apr 12, 2004 | 07:15 PM
twokrx7's Avatar
Need more sleep
Your stock map should get you to the dyno if you don't get into boost. If you want to get conservative you could pull timing and add fuel. Just start it up and go to the temp maps and pull out 3 deg leading and trailing and add 4% fuel. This should be very conservative but you may get an nasty injector transition stumble. Drive slow and keep your foot out of it until it gets tuned!
immanuel__7
89
Sep 5, 2015 10:23 AM
Microtech
Aug 23, 2015 11:04 AM
Snook
Aug 15, 2015 08:18 AM
