Gas door broken - help?
Old Oct 31, 2001 | 03:49 AM
Saku's Avatar
The spring on my gas door went the other day and was wondering if anyone has ever fixed this before....is it an easy fix, or a long job? The gas door usually stays shut but will fly open around corners.
Old Oct 31, 2001 | 09:41 AM
1FastT2's Avatar
Are you talking about the spring that keeps the pin sticking out?
Old Oct 31, 2001 | 12:33 PM
Saku's Avatar
I'm not sure which spring it is that's broken, all I know if that when I pull the lever to open the gas door, it will do nothing but make a little clicking sound near the gas tank. The door won't stay closed because SOME spring in there is broken I think, but I don't know which one it is.
Old Oct 31, 2001 | 01:42 PM
1FastT2's Avatar
What you need to do is go in the back of the car on the side where the gas cap is. Take up the carpet on the side and reach your hand back there. You will then be able to access the springs that keep the gas cap door closed. That way you will be able to see what spring is broken or missing. It may be just stuck, mine always use to get stuck until I cleaned it out one day, hope that helps.
Old Oct 31, 2001 | 04:08 PM
Saku's Avatar
No it's definatly broke, not stuck cause I had to slam it to close it cause it was prolly stuck before....my mistake I guess but thanks for the tips.
