Still Shaking
Old Apr 11, 2004 | 09:18 AM
red13brx7's Avatar
Still Shaking
Well I have taken it into the shop about 3 times now, and they cannot find anything wrong with it. They checked all the steering components, and balanced my wheels and everything. The thing still shakes, and its starting to **** me off. IT seems to do it more when it is cold out? For some un known reason, it doesn't do it all the time, but when it does it, it is hard to keep a hold of the damn wheel. CHECK out the previous post.. anyone else have any suggestions?
PREVIOUS POST
Old Apr 11, 2004 | 09:23 AM
maybe something bent..axle? Not sure
jimmdog's Avatar
Tires are fucked you probally have flatspots on them or you have a partial belt separation
Old Apr 11, 2004 | 09:52 AM
red13brx7's Avatar
The tires are ok though. I had them checked out, and it did the same shake with 3 different sets of tire. IT IS NOT THE TIRES! NO way, they all have flat spots and are worn, they are perfectly balanced. I am clueless right now. ANd it can't be a bent axle, it deffinitley in the front.
Old Apr 11, 2004 | 10:30 AM
mazdaverx713b's Avatar
Have RX-7, will restore
a worn steering box. there is fluid inside and they do wear down. just a suggestion.
Old Apr 11, 2004 | 10:53 AM
red13brx7's Avatar
I am starting to think that.. What should I do about it, I already replaced it once.. Maybe it just need tightened up.
Old Apr 11, 2004 | 11:18 AM
perhaps. have you checkes the box for wear or fluid level?
Old Apr 11, 2004 | 11:40 AM
GavinJuice's Avatar
Leave A Message
I see you have thorougly checked your tires, have they checked your wheels for out of roundness, or possibly a dent in the rim. Those can both throw off the the measurement of the tire balancing machine when they check it and give them different results. Thats just a thought though.
Old Apr 11, 2004 | 01:30 PM
University_seven's Avatar
maybe it's the bearings.
Old Apr 11, 2004 | 01:58 PM
red13brx7's Avatar
checked the bearings on the passenger side. And seriously it wouldn't be just one set of wheels that are messed up IT WOULD BE 3!!! So I have a hard time believing after all of them are perfectly balanced that it could have anything to do with the wheels or tires. I think I should check the drivers side bearing.. but I think it is somewhere in the passenger side. BUt I am not sure.. it is pissing me off.
Old Apr 11, 2004 | 02:00 PM
red13brx7's Avatar
Oh where is the fluid level for the steering box? I am pretty sure I know where it is, but just curious?
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
vish86
Oct 1, 2015 10:04 AM
Jmpabon93
Sep 30, 2015 04:57 PM
ncds_fc
Sep 10, 2015 03:52 AM
