fuel pump kill switch???
Old Oct 30, 2001 | 08:26 PM
kev's Avatar
kev
After reading posts about the fuel kill switch, i've decided to put one on. I have just one question though. In the posts I read they said once you have cut the middle relay wire and have attached the switch, then to run a wire from the switch all the way back to the fuel pump plug. I was wondering if I could just cut the middle relay wire, and then run a wire from one cut end to the switch, and then from the switch to the other cut end? Will this work? Or do I have to run a whole seperate wire back to the fuel pump?
-kev
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
Snoopy FD
Dec 8, 2015 01:45 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
