Sponsored by: CARiD
how to tell the LSD from non?
Old Apr 7, 2004 | 02:24 PM
recieved a rear suspension drop in my shipment from japan, all that is marked on it is FC3S RX-7, had 5 lug hubs, does anybody know how to tell the difference between a GLX and a Turbo II LSD differiential,
any help would be appreachated,
Old Apr 7, 2004 | 02:48 PM
NukeGenius's Avatar
Dim Sum owns you!
do a burnout with it, if the marks are equal on both sides than its LSD, but if one side dominates than its not. There probably is some way to look at it and determine, but I like the experimental way better
Old Apr 7, 2004 | 02:52 PM
lol, good advice, but i dont want to install it to figure it out, i want to be able to tell my customer what it is before they buy it,
www.renewedimport.com
Old Apr 7, 2004 | 03:26 PM
Cosmo Donk's Avatar
Queer
Well if you can install a halfshaft, or whatever it is that goes from the lsd to the wheel, then turn one they should go in the same direction. At least that is what it does on my 90 T2, which has an LSD.
Old Apr 10, 2004 | 12:31 AM
i think it is a LSD, i have been told that if i turn the yoke, and both shafts turn in the same direction, it is lsd, and that is what is happening,
Thanks for the help!
Old Apr 10, 2004 | 10:47 PM
rxtasy3's Avatar
a non-lsd will do the same thing. unless u can hold one of the axles as u turn the yoke and r unable to. the best way would be to put axles in, turn one and the other turns the same direction.
Old Apr 10, 2004 | 11:25 PM
so if i turn one axel and the other spins in the same direction, it IS LSD?
Old Apr 10, 2004 | 11:56 PM
rxtasy3's Avatar
u got it! it's the spider gears in the non-lsd that make them turn opposite directions.
Old Apr 11, 2004 | 12:03 AM
thanks, i will give that a shot tomorow,
thanks for the help,
info@renewedimport.com
Old Apr 12, 2004 | 03:10 PM
Cosmo Donk's Avatar
Queer
Oops. I couldn't remember which one it was.
L
Same
Direction
Josh83rx7
Oct 2, 2015 07:13 AM
Josh83rx7
Sep 24, 2015 11:47 AM
