anyone has a fuel pressure guage?
Old Oct 30, 2001 | 01:31 PM
puma's Avatar
canadian monster
installed inside?
Old Oct 30, 2001 | 01:58 PM
the_saint's Avatar
I am using a Nordskogg fuel pressure sender and gauge and have it mounted above my stereo using the SAAB Din panel.
Works great and installed in about 20 minutes.
Mike
Old Oct 30, 2001 | 02:06 PM
puma's Avatar
canadian monster
ok here is a question for you
what is the pressure you read at WOT, at idle.
Do you ever read 50 PSI or more?
please tell me.
thanks
puma
Old Oct 30, 2001 | 02:11 PM
the_saint's Avatar
Pressure reads around 38 at idle.
At WOT it read aroud 55 psi. (13lbs of boost)
Does that help? what does your read?
Old Oct 30, 2001 | 02:47 PM
puma's Avatar
canadian monster
i read 50, is it enough? i have a strong hesitation at WOT and it is not the 3k hesitation.
Old Oct 30, 2001 | 03:32 PM
cewrx7r1's Avatar
Eye In The Sky
I have the AutoMeter and it is way better than the Intellitronix
which I had before.
Idle pressure by the manual is about 28 to 32 psi.
By 0psi boost, it should be 38psi.
Above 0psi boost, it should be equal to 38+ the boost.
So for 12psi boost, fuel pressure should be 50psi.
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
