Wheels
Old Oct 30, 2001 | 09:46 AM
Speed Addict's Avatar
Wheels
Hi everyone, I just bought a 1990 GTU model.
I am trying to find out how wide of wheels I can get without rubbing or sticking out past the fenders. I also need to know the offset for any recommended width (if at all possible). The front and rears do not have to be the same width, so if I can use wider wheels in the back than in the front I probably will.
Any help is appreciated.
Old Oct 30, 2001 | 03:12 PM
SpeedRacer's Avatar
Formula Mazda Driver
Well, I know you can go 8" wide with a 38mm offset, and I'm sure with smaller offsets you could go wider.
Old Oct 30, 2001 | 05:31 PM
Ryde _Or_Die's Avatar
Ok, we know 8" wide with 38 offset, what about tires for that size rim? What about 9" wide with 30 offset? I never even seen a 30 offset though. Hmm..I want wide in back and looks like 8" is the most I can get so can I get recommended tire sizes? I want 40/17, not sure on the width? Thanks.
Old Oct 30, 2001 | 06:49 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
I know that if you contact the wheel manufacturer's directly they can tell you what they can make and what they cant make. Usually its just a matter of changing a couple numbers on the CNC machine before they run it. And just cause a specific design doesnt say Mazda doesnt mean they cant plug in out bolt pattern. Try finding a cool rim for a 6 lug dodge dakota and you'll understand.
FB_Frank85
Sep 6, 2015 11:29 AM
