Power FC Datalogit/wideband 02
Old Apr 5, 2004 | 01:23 PM
Smile Datalogit/wideband 02
Hello,does anyone know how to link the techedge wideband 02 in to the datalogit so that i can start logging as im not sure how to do it,thanks for the help,Roy.
Old Apr 5, 2004 | 07:04 PM
cewrx7r1's Avatar
Eye In The Sky
Basically:
(1) pick one of the AN(1 - 4) connectors for your 5 volt
input from the Techedge 5 volt output.
(2) set that AN?; main screen - setup - auxiliary.
Includes setting up the proper poly.
(3)on the monitor screen, select AUX A/D.
After all are set up properly, test when car is idling and blipping throttle. Some WBs have needed a ground wire also connected between the WB control unit and car or DATALOGIC. Do a search for more info.
Old Apr 5, 2004 | 11:49 PM
jpandes's Avatar
Answers to ALL your questions with Pics.
I asked this question before. Some really good info here: https://www.rx7club.com/showthread.p...hlight=jpandes
Thanks Jeff48!
rx7tt95
Aug 28, 2003 10:52 PM
