Innovative GTS 58 Dual Ball Bearing
Old Apr 1, 2004 | 11:08 PM
modrx7's Avatar
anybody know anything about this turbo, what does it compare too? might buy... Does it compare to a gt40r or what
Brand new Innovative GTS 58. Big shaft to handle high thrust loads. The proprietary compressor wheel handles 65lbs per hour of mass flow at up to 80% efficiency!
-Dual ball bearing center section
-T4 P trim turbine wheel
-.84 tan divided turbine housing
-3.5" v-band discharge
Great street turbo that spools up super fast and holds on strong
Old Apr 1, 2004 | 11:34 PM
Manolis_D's Avatar
Sounds like it's got a compressor about 10% larger than a 60-1. Max power would be right around 450-500rwhp (again, about 10% more than a 60-1). Other than that it sounds like a regular TO4B Turbo. I think it'd be hard to get that power with the .84 housing.
-Manolis
Old Apr 1, 2004 | 11:40 PM
Carl Byck's Avatar
Mad Man
That turbo would spool very fast, make ~370, and belongs on a Supra (it's for sale on Supraforums)
Old Apr 1, 2004 | 11:46 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Glad that you surf both forums Carl. That surely helps!! I would just go with a GT40 or a 63-1 if you can find one!
Zach
