Need Advice for New Engine
Old Oct 29, 2001 | 03:25 PM
finnicky7's Avatar
26.55 psi T04Z Monster
Well it finally happened!!!
My 94 decided to commited suicide, but oh well I got almost a full year out of this engine. Anyways, I am in search of a good shop that make quaility 13b's. I will be looking to go with 3mm seals and a street port on this engine. I had a street port on the previous, but the shop said 3mm were a waste...yeah ok.. Well if any of you guys know some good shops that make top of the line streetable engine PLEASE respond.
Thanks
Tim
1994 RX7
"Had" 13b REW streetport
T-70 p-trim
HKS super drager
HKS sequential blow off
Broward race clutch
Custom FMIC
Unorthdox pulleys
Pettit Unlimited ECU (FOR SALE)
Cosmoz Fuel pump
Greedy Profec B
Greddy Turbo Timer
Greddy Intake Elbow (boss)
Greddy Gauges
Old Oct 29, 2001 | 11:18 PM
Tim McCreary's Avatar
What caused your engine failure? Determine that before wasting money on 3mm seals. One ping and they break just the same as a 2mm. Once determined what caused the failure, spend the extra money to safeguard against it. Sounds like the car is built up, what safeguards do you have?? From your post, it appears the apex seal broke. Don't always assume the 3mm is going to last any longer than the 2mm.
Tim
Old Oct 29, 2001 | 11:42 PM
vosko's Avatar
Just Call Me Terminator!
www.pettitracing.com
www.kdrotary.com
www.jrsrotaryperformance.com
www.pineappleracing.com
www.mazdatrix.com
www.atkinsrotary.com
i think thats enough
Old Oct 30, 2001 | 12:12 AM
finnicky7's Avatar
Thanks for the links, but I was hoping someone has dealt with any of them personally.
Thanks
Old Oct 30, 2001 | 12:16 AM
finnicky7's Avatar
Tim
What safe gaurds would you recommend?
Old Oct 30, 2001 | 08:31 AM
badass7's Avatar
Pimpin Rotors...and Hoes
Definitely KD Rotary and Pineapple racing are the two to consider. Call up KD and talk to Dave.
Old Oct 30, 2001 | 08:33 AM
badass7's Avatar
BTW, what was the cause of your engine failure?? I see that you had an Intercooler and Pettit unlimited, and fuel pump. Were you just running excessively high on the boost or something??
Old Oct 30, 2001 | 01:30 PM
finnicky7's Avatar
Well if I was to take a stab at what caused my engine failure..
1st off it had a fan failure caused by a poor filter placement on the fans. This caused a short in the fan motor, which equaled a sky-rocketing temp. The engine seemed to be ok but then the stock turbos failed. So I upgraded to a T-70 p trim, but the boost was only at 10lbs peak. More than likely the seals were damaged during the over heat and the added boost pushed them to the edge. This is only my geuss I am not an expert by any means. I appreciate all of the advice though. I plan to safegaurd this engine far more than the last. Feel free to ask any thing else.
Old Oct 30, 2001 | 01:57 PM
black99's Avatar
Lurking..................
Anyone have any experiance with pineapple racing??... From the looks of their webpage it seems they have fair prices and seem to know what they are doing...
Old Oct 30, 2001 | 01:59 PM
Someone on here is running 2mm ceramic seals with a streetport and i seem to remember him being very satisfied with his setup. do a search and see what advice he can give you about ceramic seals.
Old Oct 30, 2001 | 02:05 PM
Poweraxel's Avatar
Rob golden at pinapple racing is the man..he does my motors
The1Sun
Mar 18, 2018 11:08 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
fastrx7man
33
Sep 2, 2015 09:42 PM
20B Forum
Aug 19, 2015 01:47 PM
tridav3
Aug 17, 2015 06:32 PM
