Sponsored by: CARiD
won't shift into reverse
Old Mar 31, 2004 | 04:34 PM
donniejacks's Avatar
Question won't shift into reverse
I have 1986 RX-7 and I can't shift into reverse but i can shift into all the other gears. What do I do?
Old Mar 31, 2004 | 05:13 PM
Falcoms's Avatar
kill it with BOOMSTICK!
The reverse lockout in the transmission that keeps you from shifting from 5th to Reverse may be jammed, but I'm no trans expert, just one of the things that I have seen stick before.
Old Mar 31, 2004 | 10:30 PM
hoe's Avatar
hoe
try a double clutch movement, or pump the clutch, it always worked for me.....
Old Apr 1, 2004 | 09:15 AM
Cosmo Donk's Avatar
Queer
"Star trekkin' accross the universe. Only going forward cause we can't find reverse!"
Sorry, just had to
Can you shift into it with the car off? Do you ever have any grinds in the other gears? Is your reservouir filled up? Any leaks?
Old Apr 1, 2004 | 02:12 PM
I'll check the reservouir and I don't know anything about a transmission lockout and how would I fix that? thanks for your help
msilvia
164
Mar 8, 2020 08:00 PM
teebeekay
Sep 16, 2015 01:54 PM
REX7&Z32TT
Sep 14, 2015 08:46 AM
