Bling Bling Brakes
Old Mar 30, 2004 | 10:40 AM
SomeGuy_sg's Avatar
Cool Bling Bling Brakes
http://www.zmibrakes.com/home.html
check these suckers out , ti brakes for that extra bling . they sound good , but i wonder how they would hold up on the road or track ?
Old Mar 30, 2004 | 11:13 AM
Fatman0203's Avatar
They look nice as hell but I highly doubt they would stand long on a track.
Old Mar 30, 2004 | 03:33 PM
clayne's Avatar
PV = nRT
The thermal conductivity of titanium (Ti) is inferior to other metals such as aluminum, copper, iron, and steel.
Code:
Heat capacity:
 Aluminum 2024-T3  963.00 J/kg*°C
 Aluminum 6061-T6  963.00 J/kg*°C
 Aluminum 7079-T6  963.00 J/kg*°C
 Copper - pure     385.00 J/kg*°C
 Iron              440.00 J/kg*°C
 Silver - pure     235.00 J/kg*°C
 Steel AISI 304    503.00 J/kg*°C
 Steel AISI C1020  419.00 J/kg*°C
 Titanium B 120VCA 544.00 J/kg*°C
 Water             4216 J/kg*°C
Thermal Conductivity:
 Aluminum 2024-T3  190.40 W/m*°C
 Aluminum 3003     233.64 W/m*°C
 Aluminum 6061-T6  155.80 W/m*°C
 Aluminum 7079-T6  121.10 W/m*°C
 Copper - pure     392.90 W/m*°C
 Diamond           550.00 W/m*°C
 Iron              83.50 W/m*°C
 Silver - pure     417.10 W/m*°C
 Steel AISI 304    16.27 W/m*°C
 Steel AISI C1020  46.73 W/m*°C
 Titanium B 120VCA 7.4420 W/m*°C
Thermal expansion coefficient:
 Aluminum 2024-T3  22.68 µm/m*°C
 Aluminum 6061-T6  24.30 µm/m*°C
 Aluminum 7079-T6  24.66 µm/m*°C
 Copper - pure     16.56 µm/m*°C
 Silver - pure     19.80 µm/m*°C
 Steel AISI 304    17.82 µm/m*°C
 Steel AISI C1020  11.34 µm/m*°C
 Titanium B 120VCA 9.3600 µm/m*°C
http://www.apo.nmsu.edu/Telescopes/S...roperties.html
http://www.titanium.org/discus/messa...er2620031217pm
If you want fat brakes, make them out of diamond.
Old Mar 30, 2004 | 03:39 PM
rynberg's Avatar
Funny that they claim the reverse on their website. What a bunch of crap.
Yet another product for people with more money than brains.
Old Mar 30, 2004 | 03:46 PM
DamonB's Avatar
I think there's a lot more marketing than braking going on here
When I look at the way that rotor is milled I see a big spring. Everyone also realizes these rotors are thinner than stock?
They do have two FD kits though. One with 12" rotors for $3600 and one with 13" rotors for $3725. Keep in mind their kits are only for the fronts!
Oh well. There was a pic in the FD section earlier this week of an STI rear caliper bolted to the rear of an FD. Everyone was ready to buy it and they have no idea wtf it will do for the car, let alone if it's even better than stock!
clayne's Avatar
PV = nRT
Not only is titanium incapable of conducting heat quicker than say aluminum or steel, it also has less ability to store heat for the same amount of mass.
And yea, another product for externally fashion-focused individuals to dump cash on.
Old Mar 30, 2004 | 03:51 PM
DamonB's Avatar
From the website here are the 4 pillars of ZMI:
Rotational Weight - reduce the amount of rotating weight for faster acceleration, better handling and improved braking performance
Un-sprung Weight - reduce the amount of weight in a brake system to help reduce un-sprung would lead to a more responsive suspension
Gyroscopic effect - by reducing rotating weight you can reduce the gyroscopic effects and improve steering response
Balanced Brakes - a balanced system allows the front and back brakes to work together to stop a vehicle in a controlled but very fast manner
I must give them credit. No where in there does it say you will stop quickly! What a bunch of sh*t.
Old Mar 30, 2004 | 03:56 PM
clayne's Avatar
PV = nRT
I noticed the same thing Damon.
I see a lot of shouting and yelling on their part about the reduction of rotational and unsprung weight (plus they really love to talk about the gyroscopic issue as if we're driving a motorcycle) - which is all valid - but the mention of thermal abilities seem to be very minimal.
If Ti's thermal conductivity and storing abilities are crap compared to aluminum, where's the heat going to go when the pad has nowhere to transfer it to?
As far as I can tell, nowhere. Which means the ability for the pad to actually generate friction (i.e. transfer kinetic to heat) will reach a saturation point very fast unless you had an awesome ducting setup.
I wonder how this setup works with narrow tires vs wider tires?
Old Mar 30, 2004 | 04:02 PM
clayne's Avatar
PV = nRT
I just remembered the great elastic properties of titanium as well.
Bouncy rotors.
See, titanium still gets a lot of hype. Sooner or later the public will have to realize that properly structured aluminum is pretty damn good - from a weight standpoint.
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
