fd door speaker wiring
Old Oct 29, 2001 | 08:46 AM
puma's Avatar
canadian monster
anyone changed their wiring when changing their front speaker?
How do you pass wires by the plastic connector on the door and on the body?
thanks a lot
puma
Old Oct 29, 2001 | 11:13 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Are there any empty pins in the connector>? If so just drill it (gently!) and pass the wire through. Unless you using 12AWG-10AWG speaker wire.
Then ya screwed...
Old Oct 30, 2001 | 07:05 AM
puma's Avatar
canadian monster
hmm i will check but it is pretty hard to stick your head in there...
Old Nov 2, 2001 | 03:35 PM
Reef's Avatar
I ran the wires through to the engine bay and back to the doors through the space behind the fenders. Then I cut into the loom that houses the wires for the power window and lock and pull the wire into the door. This was my solution for routing two pairs of speaker cable into the doors.
You have to partially remove the fender well inserts (the part that prevent mud and dirt from going up into the fender well) to find the path from passenger compartment to the engine bay. On the driver's side (RT) there is a spare hole through the fire wall, on the passenger side (LT) you have to run the cable through already crowded hole. Once inside the engine bay you can route the cable back behind the fender to the doors. Be very carefull when you cut into the loom. And to make the cut weather proof use electrical tape to wrap around the loom and the new cables. Good luck.
Old Nov 3, 2001 | 09:41 AM
puma's Avatar
canadian monster
hmm i don't quite understand why you have to pass by the engine bay, isn't the plastic connector under the dash?
thanks a lot
oh and by the way, i know about that place, this is where i passed my wire for the battery relocation.
Old Nov 4, 2001 | 09:10 PM
Reef's Avatar
That was the path I used in order to avoid drilling through the body or the plastic connector. I did not want to have to remove the doors to get a drill in there. And I also wanted to avoid the risk of damaging wires with drill bit.
Old Nov 5, 2001 | 07:02 AM
puma's Avatar
canadian monster
oh you didn't pass by the plastic connector? man i am confused, did you do a hole in the door? Please, give more details.
if you could take any pics, it would be really great.
thanks a lot for any other info
puma
Old Nov 5, 2001 | 04:35 PM
Reef's Avatar
I want to apologized the wires did not go all the way to the engine bay. I ran the wires through the fire wall and then under the fender to the connector in the door. (The two holes that I used is under the fender.) I then made a small cut in to the rubber tube that house the power window and power door lock wires. Then pulled the wire through into the door.
By the way, if you only need one pair of wires to the door, I would reuse the one in the stock harness. I was not able to reuse the harness because the crossover would not fit in the door. So I had to run two pairs to each door.
If you open the door you will see that there is a space behind the fender that runs the length of the fender to the tires. It is through that space that I ran the wires. Again, sorry about the confusion.
ppritchard
Interior / Exterior / Audio
Sep 2, 2015 07:44 PM
ppritchard
Aug 21, 2015 06:02 PM
