1985 12a problem please help
Old Mar 29, 2004 | 02:42 PM
INDITEN's Avatar
car wont start without the choke. has been sitting for a long time. when i release the choke the cars just dies. I push the accelerator when the car is off, it wont pump gas. what should I do. please help.
Old Mar 29, 2004 | 04:27 PM
redrx's Avatar
considering that the choke changes you air/fuel mixture, your problem could be a bad fuel to air ratio, first you would want to check the easy stuff like your fuel filter, and if the car starts for a second, then dies, then your fuel pump (mechanical) or fuel lines may need to be replaced, im sure someone on the forum has had this problem before, but not me
Old Mar 29, 2004 | 04:34 PM
Dirtleg's Avatar
I would fix your accelerator pump first. You probably aren't getting enough fuel to start the engine. Choke richens the fuel mixture so thats why it will start with the choke on.
The1Sun
Sep 18, 2015 12:34 AM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
