Fuel return line size.
Old Mar 28, 2004 | 05:43 PM
Marcel Burkett's Avatar
Question Fuel return line size.
Dont think I am reposting since I cant find my previous one (moderators ?) , anyway , I finally got my twin Bosch '044 pumps installed and will be starting up tomorrow (after I get my 180 deg fittings) , I was told that those pumps would cause an idle pressure of about 60 psi with the stock return line , can anyon say if this is so or not ?.
Old Mar 30, 2004 | 10:15 PM
RX794's Avatar
NYC's Loudest FD
Not true.
Old Apr 2, 2004 | 02:47 PM
No not true ......, I started up and found that my fuel pressure went up by only 2 psi , from 39 to 41 .
Old Apr 2, 2004 | 04:50 PM
setzep's Avatar
Not bad, I would have thought 5-10 psi. That's a lot of fuel you're shoving through the return at idle
Old Apr 2, 2004 | 05:07 PM
RETed's Avatar
It depends on your feed size?
As a rule of thumb, you go down one AN size versus the feed size.
-8AN feed, -6AN return
-10AN feed, -8AN return
-Ted
Old Apr 3, 2004 | 10:30 AM
i am running - 8 AN from the pumps into a NOS Y fitting , from which it goes to a -10 AN supply hose , the -6 return is attached to the stock return line.
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
