Mazadatrix Rad
Old Mar 27, 2004 | 12:41 PM
g prime's Avatar
Mazadatrix Rad
I just bought a mazadatrix replacement rad for my 81'. At the bottom there are two metal tubes coming out of the center, what are these for, If I don't connect them will coolent come shooting out. My current rad has everything else but that. Thanks
Old Mar 27, 2004 | 12:44 PM
dirty86's Avatar
automatic transmision fluid cooler lines
no fluid will come out
Old Mar 27, 2004 | 01:48 PM
g prime's Avatar
Thanks for the quick reply.
Old Mar 27, 2004 | 01:51 PM
Could you use the auto trans cooler for an oil cooler if you have a manual?
Old Mar 27, 2004 | 02:04 PM
dirty86's Avatar
i asked that question but noaboady awsnserd
Old Mar 27, 2004 | 02:34 PM
hornbm's Avatar
FD > FB > FC
I guess, although gear oil heating is not much of a problem anyway.
Old Mar 27, 2004 | 03:48 PM
Jeff20B's Avatar
Lapping = Fapping
Heating the gear oil with those tubes would be a problem. Gear oil is also thicker than trans fluid.
Old Mar 27, 2004 | 03:52 PM
dirty86's Avatar
how about motor oil
Old Mar 27, 2004 | 04:36 PM
Lotus00's Avatar
I dont think that little part of the radiator used for transmission cooling would be enough for cooling the oil.
Old Mar 27, 2004 | 04:41 PM
dirty86's Avatar
yes but look at the bee hive
Old Mar 27, 2004 | 04:46 PM
Lotus00's Avatar
I have never seen a beehive oil cooler... are they really small?
anyway, I still dont think it would work, the fittings are really small. (compared to the ones on my 82 oil cooler)
Old Mar 27, 2004 | 09:24 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
just plug those two pipes with rubber caps
Old Mar 27, 2004 | 10:58 PM
jamo's Avatar
Newbie
you cant use that for man trans cooler because there is no pump on the man. trans to pump the fluid through the cooler. it would just sit there.
Old Mar 27, 2004 | 11:44 PM
I didn't say anything about gear oil or using it for cooling the manual transmission. What I meant was, if you have a car with a manual transmission, can you use the cooler for engine oil.
Old Mar 28, 2004 | 12:41 AM
Jeff20B's Avatar
Lapping = Fapping
Beehive tubes are bigger.
