Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Safc S-afc 2
Old Mar 26, 2004 | 10:59 PM
J.S.J's Avatar
Safc S-afc 2
I got a SAFC S-AFC 2 and since then I was told it does not work well with the 3rd gen. I am not sure what the reason is but I do see how the 3rd Gen's throttle sensor is set up and how it's divided up in two sections. My goal with this unit is to counter the low vacuum created by my street-port engine. I am counting on being able to trim the M.A.P sensor input at idle and really that's about all. Some input from someone who has some ideas would be appreciated.
Old Mar 29, 2004 | 09:26 AM
Cosmo Donk's Avatar
Queer
So do you need to adjust the TPS signal or the MAP signal, or both? I have the Cosmo engine, which has the same TPS, so hopefully this diagram that Matt "The Hitman" drew up for me, will help.
Old Apr 26, 2004 | 09:23 AM
surfpac's Avatar
I did not hook up the SAFC to the TPS output. I'm using the MAP sensor output instead, so my high throttle maps comes at a certain boost point.
http://www.sddsm.org/pages/vfaq-maphack.htm
AlixxxilA
Dec 24, 2001 08:50 PM
penko
Rotary Car Performance
Nov 30, 2001 11:37 PM
RXTASY1
Aug 25, 2001 11:37 AM
