Help identify Dellorto carb part.
Old Mar 26, 2004 | 06:37 PM
13BTOY's Avatar
Boosted Fb
Hey guys I was cleaning out my carb and when I flipped it over to drain some of the carb cleaner out a small stainless steel ball bearing fell out of the fuel bowl. I looked in the bowl and notice a small hole in the center. I placed the ball bearing in and it sits in there. Is this where its suppose to be? Also what is it for?
Thanks, Ed
By the way my Holley blue just came it and I let you know if it solves my high rpm miss/stumble.
Old Mar 27, 2004 | 01:55 AM
DriveFast7's Avatar
Blood, Sweat and Rotors
there are two of those steel ball bearings. they go not IN the float bowl, but right next to it. there are two brass plugs with flat heads to unscrew the plugs. put one ball bearing under each brass plug. and screw the plug ontop.
http://www.gruntled.com/Dellorto/Diagram.html
Part number 51. Pump jet ball bearing. You don't need the weight ontop of it, part number 50.
Old Mar 27, 2004 | 05:50 AM
13BTOY's Avatar
Boosted Fb
Man thanks for the input. Im going to see is the other is wher is suppose to be...
Thanks, Ed
scissorhands
Oct 8, 2015 01:17 PM
