Water Injection Level Sensor
Old Mar 26, 2004 | 01:17 PM
pistonsuk's Avatar
i want to install a level sensor in the water tank. i would like an LED to light when the levels falls below 1/4 or so.
what is the least expensive, reliable way to to this?
justin
Old Mar 29, 2004 | 05:58 PM
drift-sport's Avatar
If you found a car that had a windshield washer level detector in it stock you might be able to go to a junk yard and pull it from the same model. Just an idea if you are looking for something cheap.
Evan
Old Mar 29, 2004 | 08:06 PM
93BlackFD's Avatar
built my own engine
use the stock FD water level sensor, it grounds out when water is present
Old Mar 31, 2004 | 02:14 PM
patriick's Avatar
FD enthusiast
Only if the water container is metal.
Old Apr 7, 2004 | 10:34 AM
93BlackFD's Avatar
built my own engine
damn, really?
Old Apr 7, 2004 | 02:22 PM
patriick's Avatar
FD enthusiast
Yeah, the sensor works in the FD because the thermostat housing is metal and grounded. Since it's a single-wire sensor it needs the housing (and water) to act as a second electrode to complete the circuit.
You can still use the FD sensor with a non-metallic container if you add another electrode (or a second water sensor) to the container, but this is probably more trouble than it's worth, since there are off-the-shelf sensors that are made for this type of thing.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
msilvia
15
Sep 11, 2015 12:13 PM
mulcryant
Sep 9, 2015 05:24 PM
