Sponsored by: CARiD
13b non turbo to turbo?
Old Mar 26, 2004 | 12:14 PM
bjohnson's Avatar
i have just bought an 88 13b turbo motor for my 91 13b non turbo does anyone know what i need for this motor swap im not sure.
Old Mar 26, 2004 | 12:39 PM
jeremy's Avatar
male stripper
you can use the wiring harness but you will have to do some splicing and gain a lot of know-how. you will also need the turbo ecu. its a good thing to upgrade the drivetrain as well, sine the turbo motor will kill the na tranny rather easily. pretty sure the flywheel etc needs to be changed to work with the na tranny.
Old Mar 26, 2004 | 03:15 PM
mazdaverx713b's Avatar
Have RX-7, will restore
in addition to this, try a search in the 2nd gen specific section.
Old Dec 14, 2004 | 11:58 PM
spitfire7's Avatar
i did the same swap . i got spark , but no fuel. after the cpu wharness ,and hood ull need to run 4 wires of the crank ang sncr ,and splice them into the chassis harns . after that i thought i was finished,i was wrong. did u finish ur 7 if so how did u do it.thanks
Machupicchu
Aug 17, 2015 08:27 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
