GSL-SE ECU works with 12at?
Old Mar 25, 2004 | 11:06 PM
timmya2's Avatar
Question GSL-SE ECU works with 12at?
just wondfering if a stock ecu from a gsl-se 13b N/A will work with a stock 12at..
cheers guys
Old Mar 25, 2004 | 11:29 PM
Swolbynos's Avatar
Newb
wouldnt think so...
but im not sure
Old Mar 26, 2004 | 08:50 AM
Directfreak's Avatar
I am a Jeeper Now.
no
Old Mar 26, 2004 | 03:05 PM
mazdaverx713b's Avatar
Have RX-7, will restore
not even close. the SE ecu controlls the fuel injection and since the SE wasn't offered with an auto trans, it would have nothing for it.
Old Mar 26, 2004 | 04:00 PM
REVHED's Avatar
Hunting Skylines
Why would you even ask a question like that? You can get a fuel only Microtech to run a 12AT for about $500 bucks.
Old Mar 26, 2004 | 06:25 PM
dirty86's Avatar
lol i think he's meaning turbo
Old Mar 26, 2004 | 07:50 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
Well, the answer is going to be 'no', because the stock N304 ECU for the SE is designed to run 2x680cc injectors under normally aspirated (atmospheric) conditions, not boosted.
As soon as you boost your engine intake pressure above atmospheric, you're going to need custom mapping to keep up with the air going in. This usually requires some kind of ancillary controller that can be mapped, adjusted, and tuned on a dyno for best performance.
The N304 ECU relies on a lot of input signals to get good performance for 13b non-turbo applications, and running a turbo would quickly overpower the stock AFM, you'd be running lean, and your engine would pop like popcorn on a Friday night.
Sorry,
Old Mar 26, 2004 | 08:01 PM
who knows. perhaps he should specify a tad more.
Old Mar 26, 2004 | 08:22 PM
hornbm's Avatar
FD > FB > FC
what did you think 12at stood for? Your in the land down under man, you should know this stuff.
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
