caliper rebuild
Old Mar 25, 2004 | 06:11 PM
caliper rebuild
has anyonr rebuilt rear 86 calipers is it hard too do
Old Mar 25, 2004 | 06:15 PM
eyecandy's Avatar
Honestly, you would be better to just get some good used calipers, or send them out to get rebuilt. Because they will prolly end up leaking again in like a year...
Old Mar 25, 2004 | 07:04 PM
Kenteth's Avatar
Like Ghandi with a gun
go to aap and ask for rebuilt calipers. There like $50+core for 1pots. the rebuild kits are at least $20/caliper anyhow...
Old Mar 25, 2004 | 07:09 PM
incendui's Avatar
I've heard the rear calipers are tricky because of the e-brake mechanism in them. I'd reccomend buying rebiuilt ones also, theyre not that expensive.
Old Mar 25, 2004 | 07:54 PM
alberto_mg's Avatar
I have an old set of calipers off of my 88 Turbo II if anyone is interested pm me...
Old Mar 25, 2004 | 08:41 PM
Wankel7's Avatar
Haven't we ALL heard this
I would just go buy rebuilds for the rear. I tried to tackel the rebuilding the rears. But there is a snap ring that is deep in the bore that needs to come out to do a COMPLETE rebuild. I decided to just do the piston seal and the piston dust boot in my rebuild. It works and doesn't leak.
But in the future I would just buy rebuilt rear calipers.
However, in the front just rebuild those your self. It will take a few hours but you will save money in the long run!
James
Old Mar 25, 2004 | 09:10 PM
Russ's Avatar
i sandblasted and rebuilt mine using the kit from mazdatrix. it wasnt all that hard i think they turned out pretty good.
Old Mar 26, 2004 | 08:21 PM
ok thanks guys
Old Mar 26, 2004 | 11:00 PM
Wankel7's Avatar
How did you rebuild the parking brake portion of the rear caliper. How did you take it apart?
I was going to remove the snap ring and then it should all come out. But I didn't do that.
James
Old Mar 26, 2004 | 11:10 PM
Wankel7's Avatar
How did you remove the parking brake portion of the rear caliper? Just wondering which way you went about it.
JAmes
angel824
Mar 17, 2019 09:44 AM
Vartok
Sep 24, 2015 02:20 PM
04G35S
Sep 9, 2015 07:05 AM
