Power FC how accurate is the knock reading on the power fc?
Old Mar 25, 2004 | 02:44 PM
1FooknTiteFD's Avatar
Ghost Ride the Whip
Just wondering how acurate it is....
sometimes i see readings of 196 or 152 while other times it's extremeley low....
My AFR is tuned at 10.8 to 1 so it's super rich, what do you guys think?
Old Mar 25, 2004 | 03:37 PM
rynberg's Avatar
The knock sensor is simply a piezoelectric microphone mounted in the block. If the wiring or mic are loose or bad, you will get higher knock readings.
Also, you have to really look at when you are getting the high readings. Many people get very high levels of "knock" when they shift or let off the throttle. If you are getting levels that high under constant WOT, then something is wrong -- either with your knock sensor or your tuning/engine.
Old Apr 2, 2004 | 11:32 PM
paximus's Avatar
20B FD|20B Cosmo|S5 TII
rynberg summed it up pretty good. i'd see over 100 on the commander, and only 30 on the datalogit. so i dont know what the deal is. kinda weird. anyone have any suggestions?
Jun 26, 2016 10:21 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
elfking
Aug 19, 2015 09:48 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
