Brembo rear brake with SSR 18x12 wheel
Old Mar 25, 2004 | 04:30 AM
rotaryextreme's Avatar
Veteran: Navy
I have a set of STI brembo brake and test fitted them on the FD.
Chuck Huang
Old Mar 25, 2004 | 04:16 PM
POM HB's Avatar
Lookie Only
Chuck,
The brake bolted right up?
POM HB
Old Mar 25, 2004 | 06:06 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
u sellin it? how much?
Old Mar 25, 2004 | 07:26 PM
DamonB's Avatar
Nobody is concerned with piston size/pad area etc?
Just bolting on a caliper that says "Brembo" doesn't guarantee improved performance on a car for which it wasn't intended.
Old Mar 25, 2004 | 07:39 PM
Veteran: Navy
Nope. Custom bracket needed.
Chuck Huang
Originally posted by POM HB
Chuck,
POM HB
Old Mar 25, 2004 | 07:40 PM
Veteran: Navy
Yes and no. If there are 10 people interested, I can mass produce it. If not, I will be the only one to have it.
Chuck Huang
Old Mar 25, 2004 | 07:41 PM
Veteran: Navy
Don't you worry. I have matching front and back.
Chuck Huang
Old Mar 28, 2004 | 03:29 PM
POM HB's Avatar
Lookie Only
If you were to sell them, how much for the 4-wheel kit, rear kit, and only front kit? Are the set new or used from STI?
Old Mar 28, 2004 | 03:40 PM
Veteran: Navy
The one from STI do not bolt on. The only thing you can use are the caliper and the pads. The ones on my car are used. I bought them from for R&D.
I don't really plan to sell them unless I can pre-sell at least 10 sets.
If I were to sell them, the front kit will come with caliper, extension bracket, brake rotor with aluminum hat, brake pads and brake lines. The rear kit will come with the same components. Front will be $2600 and rear will be $2200 using all brand new parts.
Chuck Huang
Old Mar 28, 2004 | 05:13 PM
VincenzoL's Avatar
Cali Maki OG
From what i know the STI, EVO, and 350Z are all using the same Brembo calipers. Do all these cars have the same size master cylinders too?
MILOS7
Aug 19, 2015 07:25 AM
Marty RE
Aug 17, 2015 09:36 AM
Marty RE
Aug 13, 2015 11:19 AM
