Trust Rebic LC???
Old Mar 24, 2004 | 11:32 PM
turboii87rx7's Avatar
Trust Rebic LC???
is this fuel control system any good?
i can get it for about $260, is it worth it?
it says it will also remove the fuel cut. Im looking to run my car around 10psi w/ a walbro, and this fuel controller?
what do you all think???
is it worth it?
thanks
Old Mar 24, 2004 | 11:45 PM
i really need some help w/ this b4 the deal is taken.
thanks
edit: Where are you NZConvertible? I need your input... lol.
Old Mar 25, 2004 | 12:33 AM
bump... really need input asap
Old Mar 25, 2004 | 01:04 AM
RETed's Avatar
Isn't this the simulator that works only with the Rebic III or IV?
-Ted
Old Mar 25, 2004 | 01:08 AM
its on ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWA%3AIT
Old Mar 25, 2004 | 01:15 AM
RETed's Avatar
Oops, sorry, my mistake.
I did a quick web search, and it looks like it's similar to the HKS PFC F-CON.
Sorry, I don't have any direct experience with it.
Oh, if you haven't already noticed, it's only for Kouki FC turbos.
I noticed you have an "87" listed, so it will not work for that model.
-Ted
Old Mar 25, 2004 | 07:54 AM
yea, i asked him if it would..... i was hoping that it would somehow work
lol
Old Jun 7, 2004 | 10:56 AM
grinder's Avatar
basically you plug it in between the ecu and the harness
it should let you run upto about 15psi
grinder's Avatar
an update as i am thinking of getting one !!
The Greddy is a piggyback ECU so the existing stock ECU stays in the car
too, works like this:
Engine Sensors ---- Greddy ---- ECU
The greddy interupts sensor signals and "cons" ECU into thinking values are
different hence giving more/less fuel etc for a given sensor reading.
Clever
You can run the greddy without upping the boost and you should see a change
in performance, it wont be massive but you will get better fueling simply
becuase the greddy/stock ECU combo perform a lot better than just the stock
ECU. With your air filter and exhaust mods the greddy will make sure you're
not underfueling (although this a lot less of a problem on the TIIs than the
third gens as the TIIs have a MAFM). Obviously wack a boost controller
(dors device would probably work just dandy according to local opinion- I
asked the guys last night and they all reckon it'll work perfect, one of
them has one on his 200SX S14 and it's running 15PSI with no spiking) and
you'll be able to up the boost to 12-14PSI and have LOADS more fun!
wickedrx2
The Bad & Fugly Members
Jun 10, 2021 06:28 PM
dqpd2003
Sep 24, 2015 11:36 AM
