No brakes
Old Mar 24, 2004 | 10:24 PM
Visago's Avatar
No brakes
Yesterday i noticed the brakes being really soft, i knew i had a problem and was heading to autozone anyway. by the time i got there i had to put my foot all the way to the floor and downshift to stop..asked inside and they said it is prolly a master cylinder, so i replaced it and the pads...pedal is still way soft not much change...any ideas?
Old Mar 24, 2004 | 10:40 PM
Did you blead the system completly?
If their is any air in their it will cause this
Old Mar 24, 2004 | 11:04 PM
Visago's Avatar
yea i did, i was planning on doing it agian tommorow, to make sure, if the bleeding isnt it, meaning no air... what else could it be
Old Mar 24, 2004 | 11:11 PM
Audiofight's Avatar
One of my rear calipers had a seal go out and it would relieve the pressure in the system slowly. Took a little while to get the pedal all the way to the floor.
Being that it is nice out now, go to a car wash and spray each tire/wheel very well and watch for the red fluid to come out of the wheel, should be soaked on the inside if a caliper is bad.
Otherwise, you already replaced a master cylinder, rules that out.
Maybe a split brake line?
Check these after you re-bleed the system though. That is the most likely.
Old Mar 24, 2004 | 11:18 PM
Visago's Avatar
i didnt notice any fluid around the front of the car, cept for what i spilled, since i didnt change the rear pads i never even looked back there, not used to having 4 wheel disks, will check it out tommorow , thanks
Old Mar 25, 2004 | 01:35 AM
nyc_scorpio's Avatar
R.I.P. Monte Negro FD
maybe the brake booster might be going out, happened to mine, but it made the brakes really hard to push down on them
Old Mar 25, 2004 | 09:24 AM
Visago's Avatar
how much was a booster?
Old Mar 25, 2004 | 09:32 AM
SureShot's Avatar
Seduced by the DARK SIDE
Basic brake troubleshooting:
Soft feel - air in the system.
Hard feel - booster or vac check valve problem.
Sinking pedal - master cylinder problem.
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
