Rear brake help
Old Mar 24, 2004 | 01:48 PM
Rear brake help
I just changed the rotors, pads and brake lines all the way around my FD. When we took the rear calipers off, neither caliper had the "v-spring" in it. Doesn't this help seperate the pads when not under braking? Is it ok to run without this "v-spring". I'm not even really sure where it hooks up, but I did see that part in the service manual, and not on my car. Any help/advice?
Old Mar 24, 2004 | 02:06 PM
IRPerformance's Avatar
Sponsor
Its to help reduce chatter. It is not needed. If you have it, then put it back in. The hooked ends go into the little holes on the brake pad.
Old Mar 24, 2004 | 02:07 PM
Thanks!
Marty RE
Aug 17, 2015 09:36 AM
Marty RE
Aug 13, 2015 11:19 AM
