How do I tell what AC comp?
Old Mar 24, 2004 | 04:05 AM
The Spyder's Avatar
Never give up!
When selecting belts...
It tells me belt for AC w/ Sanden A/C Compressor, or w/ Nippondenso A/C Compressor.
Is there a easy way to tell?
Old Mar 24, 2004 | 04:13 AM
Kai's Avatar
Kai
Rotorphile.
The compressor manufacturer should be marked right on the compressor itself...
Old Mar 24, 2004 | 05:18 AM
pip's Avatar
pip
the blackest incarnation
Even easier, with the nipon ac there is a bright yellow sticker on the driver schok tower that says warning blah blah blah and then says nippondenso at the bottom.
Old Mar 24, 2004 | 05:27 AM
The Spyder's Avatar
Never give up!
sweet, Ill check it out.
*I have no idea why i up at 3:15 am... *
Old Mar 24, 2004 | 02:19 PM
The Spyder's Avatar
Never give up!
Ok... no yellow sticker...
and the PS says KOYO on it...
The ac only has 2 noticible markings, UK on the back, and in and out.
Nothing noted in the manual.
Assume its the sanden if theres no giant sticker???
Old Mar 24, 2004 | 02:35 PM
The Spyder's Avatar
Never give up!
The ONLY sticker for the ac is a white one on the driverside firewall. Says MAZDA R12 system, blah blah blah. Thats it.
Old Mar 24, 2004 | 03:43 PM
nopistons's Avatar
If you can get a mirror (or your face) down there, I know that the Sanden has a sticker on its side that says....Sanden. (Or at least mine does.)
Old Mar 24, 2004 | 03:58 PM
MIKEHRX7's Avatar
Newbie
I beleive TII's (my 1988 anyway) came with ND compressors from the factory and the N/A's were retrofit in the states with A/C units from Sanden. The reason I know this is that I purchased one of the complete retrofit kits, took out my ND compressor and put in the entire retrofit kit and it had a Sanden compressor. I had to take a compressor mounting bracket off my 1987 N/A parts car in order for the Sanden to fit.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
