airbox problem, help!
Old Mar 23, 2004 | 08:37 PM
Hey all FC mechanics, I ran into a few problems today when taking off my radiator and air box. The air box was a noob mistake when I undid the philips screws that held in the wire harness connector. I ended up pulling it out like a noob and found myself accidentally messing up the wiring inside. Anyone know if this is a important for the car to function or if I should go and get a new one?
Old Mar 23, 2004 | 08:46 PM
heres a pic of what happened
Old Mar 23, 2004 | 08:48 PM
SwooshMan's Avatar
Ouch, gonna need a replacement AFM!
Old Mar 23, 2004 | 08:50 PM
1SxyRXy's Avatar
my fc broke
Old Mar 23, 2004 | 09:23 PM
Kenteth's Avatar
Like Ghandi with a gun
is that an s4 afm? I've never seen anything like it on my s5
Old Mar 23, 2004 | 09:27 PM
SwooshMan's Avatar
Fo' Sho'
Old Mar 23, 2004 | 09:53 PM
truespin88's Avatar
truespin, not tirespin
NOTE: The AFM does not have to come out with the airbox. It can be unbolted from the airbox while still connected electronically!
Old Mar 24, 2004 | 02:20 PM
lesson learned
Old Mar 24, 2004 | 03:10 PM
greasycheeseman's Avatar
Rotary > Piston
I did this once a long time ago... but not to worry too much... somewhere on the forum or maybe in the FSM downloadable at fc3s.org there is the wiring diagram for the air flow meter. If your good with a soldering iron, you can re-solder it yourself. Or go to a junk yard and pick one up for cheap from a dead rx.
Old Mar 24, 2004 | 03:30 PM
J-Rat's Avatar
Alcohol Fueled!
PM RXMFN7,
He might have an extra one of those.
msilvia
164
Mar 8, 2020 08:00 PM
msilvia
15
Sep 11, 2015 12:13 PM
