difference between a nonturbo rotary and a turbo rotary?...
Old Mar 23, 2004 | 08:29 PM
Is there a difference between the 2nd gen turbo internals and the non turbo internals...did they beaf anything up or strengthen it? Seals, housing...
Old Mar 23, 2004 | 08:31 PM
White_FC's Avatar
Re: difference between a nonturbo rotary and a turbo rotary?...
Yes some of the 'internals' are different, no they are not inherantly stronger.
Old Mar 23, 2004 | 08:32 PM
J-Rat's Avatar
Alcohol Fueled!
I know the rotors are lower compression, I dont think the seals are too much different though.
Old Mar 23, 2004 | 08:33 PM
Rhode_Dog's Avatar
\m/
T2 had lower compression rotors, by how much i don't know
Rhode_Dog's Avatar
\m/
oh my bad someone replied already
Old Mar 23, 2004 | 08:42 PM
thanks guys
Old Mar 23, 2004 | 10:01 PM
von's Avatar
von
turbo corner seal springls are stronger than n/a and 3rd gens might be even better I dont know
Old Mar 24, 2004 | 12:08 AM
Icemark's Avatar
Man, there are so many differences between a non turbo and turbo motor... it would be hard to put them all here and not miss some.
housing related differences:
Front housing:
aux port eliminated on turbo motors
oil suction hole added on turbo motors
Intermed housing:
intake port shape and timing changed on turbo motors
air passage for EGR eliminated on turbo motors
port air passage added on turbo motors
water passage added on turbo motors
oil level pipe shortened on turbo motors
oil filler pipe shape changed on turbo motors
rear housing:
Front and rear rotor housings:
free flow exhaust port added on turbo motors
port air passage opposite on turbo than non turbo
front cover:
oil return hole added
rotor:
volumn of rotor recess enlarged on turbo motors
cromium plating applied to apex seal grove on turbo motors
side seal:
inpregnated with molybdenum disulfide on turbo motors
flywheel:
larger diameter and heavier on turbo motors
Of course this is just for the FC, not the SA/FB and there were no non turbo FD models.
and why did you start so many thread on this same subject??? you best not be post whoring!
Old Mar 24, 2004 | 01:42 AM
RotaryResurrection's Avatar
As for interchangeability, they share one part: the eccentric shaft. And front pulley, water pump, alternator, that is about it. Everything from the engine to the axles is different. As far as what is stronger in the engine, not really anything. Just different specs/design. Everything from the flywheel back is stronger, however.
www.rotaryresurrection.com/turboconversion.htm
Old Mar 24, 2004 | 03:38 AM
drago86's Avatar
you sure turbos got differnt side seals? The part number is the same. Also I thought only the competition rotors had chrome apex groves?.. anyhow it boils down to a few water passagges, oil stuff to support the turbo, lower compression and intake exhaust ports, all the turbo/ non turbo parts can be mixed and matched to achieve the ports and compression ratio you want as long as you plug up and passages not being used in your application.
Old Mar 24, 2004 | 10:53 AM
Icemark's Avatar
I just put down what Mazda listed in 87 as the major changes between the turbo and non-turbo motors. I wouldn't be surprised if they started using the same side seals regardless of motor. As far as the chrome apex grove, I have only seen that on 87-88 turbo motors, but I have only rebuilt a half dozen total 13B/13BT motors. Kevin would probably know better.
Old Mar 24, 2004 | 11:27 AM
All the seals and springs on the 86-91 turbo and nonturbos are identical. The housings, rotors, and irons all differ.
cristoDathird
28
May 30, 2019 08:47 PM
