13B engine comparing...
Old Mar 23, 2004 | 08:06 PM
I am new to rotaries so give me a break if this sounds dumb. Is the second gen engine block the same as the third gen block? If it is what were the laragest changes between them besides the turbos and regular bolt on stuff. Any info would help!
Old Mar 23, 2004 | 08:10 PM
mwatson184's Avatar
holley guy
Different sized ports, different corner seals, different engine mounts.
Old Mar 23, 2004 | 08:26 PM
same block though?...meaning i could make a second gen non turbo block into a third gen turbo?
Old Mar 23, 2004 | 09:37 PM
Sponge Bob Square Pants's Avatar
No.
The NA engiens are completely different than the turbo engines.
As far as 2nd Gen Turbo engiens go, there are 2 types, the Series4 (87-88) and Series5 (89-91). The S5 is stronger, better ports, and is VERY similar to a 3rd Gen core.
Old Mar 24, 2004 | 03:19 AM
drago86's Avatar
Not completly differnt, all housings/plates/rotors/e-shafts can be swaped around to give you the ports/compression ration etc you want. Infact the only differance between the Na engine and the turbo is the porting, T2 has a few extra cooling passages, and a larger oil pump. while the S5 t2 engine is stronger then the s4, the ports are identical. The S6 is slightly stronger then the s5, and has much larger secondary ports and slightly smaller primary ports.
Old Mar 24, 2004 | 09:11 PM
neit_jnf's Avatar
I thought NA engines have six ports and turbos four ports?
Old Mar 24, 2004 | 09:12 PM
neit_jnf's Avatar
Old Mar 26, 2004 | 02:16 AM
yes and no,
the S4 engines are basically the same block as the S5 besides the bigger rotors, however everything besides that (oil metering pump excluded) is the same, pretty much, the long block is different tho..and which ports are you talking about? if you mean the T2- exhaust ports then yes, but from what i hear that doesn't really matter to much. the intermedeate housings on a turbo are different, along with some other things, however it's basically the same engine when you pull it apart. (turbo- non turbo).
Originally posted by Sponge Bob Square Pants
No.
Old Mar 30, 2004 | 01:33 PM
gerbraldy's Avatar
wtf's a piston
just put a 3rd gen in your car. Take off the sequential setup, sell it, get single turbo
turbo-minivan
69
Feb 4, 2016 12:29 AM
Ciclovnz
Oct 18, 2015 03:04 PM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
