add coolant light
Old Mar 23, 2004 | 11:11 AM
Russ's Avatar
add coolant light
this is bugging the hell outa me my add coolant light and buzzer come on when i start my car. but as soon as it warms up it goes away (at the same time as the aws goes off). i wouldnt mind just the light but the buzzer is anoying. my coolant level has stayed the same too. im not eating any coolant. on a side note my check engine light also comes on during hard aceleration.
Old Mar 23, 2004 | 12:05 PM
billzrx7's Avatar
fill up yer coolant, its low man
Old Mar 23, 2004 | 12:07 PM
Russ's Avatar
nope, it isnt.
Old Mar 23, 2004 | 12:10 PM
3RotorRocket's Avatar
mine does somewhat the same thing im getting really sick of it.Im tempted to just take the buzzer out.
Old Mar 23, 2004 | 12:11 PM
if the check engine light is on pull the code also check for any little coolant leaks you may find some somewhere also check the overflow make sure it is full
Old Mar 23, 2004 | 12:15 PM
Russ's Avatar
the check engine light only 'blips' on for a few seconds and goes off as soon as i let off the WOT it goes off. the coolant overflow is more the full (due to me making sure i had enuff coolant and it wasnt eating it). ill check for leaks but im pretty sure its electrical or something of that nature. thanks for all the help thus far guys keep it coming
Old Mar 23, 2004 | 01:51 PM
Bukwild's Avatar
8 times out of 10 you need a rebuild if you are loosing coolant and have no leaks.
Old Mar 23, 2004 | 02:02 PM
Russ's Avatar
but im not losing coolant
Old Mar 23, 2004 | 02:37 PM
billzrx7's Avatar
u may be burning it and the overflow means nothing. you need to actually open the radiator cap and the water neck.
Old Mar 23, 2004 | 02:54 PM
NZConvertible's Avatar
I'm a boost creep...
Originally posted by Russ
the coolant overflow is more the full...
The ADD COOLANT warning indicates radiator level is low, not the overflow bottle. You probably have a bit of air in the system. Make sure you bleed the air out of the system as you fill it.
Old Mar 23, 2004 | 10:16 PM
Russ's Avatar
is there an air bleeder valve on the rad that i should be using when i fill it? i flushed the rad 2weeks ago when i did a 60k tune up. ill probably do one again this week.
Old Mar 23, 2004 | 10:22 PM
S4 yes, S5 no.
Old Mar 23, 2004 | 10:37 PM
Russ's Avatar
whats the best way to let air out while you fill it with coolant on an s5 then?
Old Mar 24, 2004 | 05:49 AM
Make sure the heater is fully open. Fill the system up, turn the engine on and watch for air bubbles coming out the filler neck. Add more coolant as required. Keep doing this until no more air comes out, then put the cap on and go for a drive. Let it cool down and check it again.
Old Mar 24, 2004 | 06:11 AM
GEINN FC3S's Avatar
i had this buzzer problem too, i added coolant and reset my ecu right after and it went away for good. =)
Old Mar 24, 2004 | 06:29 AM
The ECU is not connected to the coolant level warning system in any way. Adding coolant stopped the warning, not resetting the ECU.
Old Mar 24, 2004 | 06:57 AM
GEINN FC3S's Avatar
??thats wierd??? i dont think i reset just the ecu, maybe i did more than that, cause all i did was take the negative off the battery terminal, stompped on the breaks a few times and reconnected it. maybe its just coincidence, the day i unplug is when it stopped buzzin for good.
Old Mar 24, 2004 | 07:03 AM
jgrts20's Avatar
Who are you?
i just posted something like this couple a weeks ago!! its probly just air in the lines/radiator!! i opened the bleeder valve on the hose and some air came out, i doesnt do it anymore now!!
https://www.rx7club.com/forum/showth...+coolant+light
thanx NZConvertible
chris
Old Mar 24, 2004 | 07:41 AM
Tofuball's Avatar
Jesus is the Messiah
Oh man, I thought i had no leaks too. But I found out my heater return hose leaked ONLY sometimes on a cold startup!
Fixed that now!
Queppa
Nov 18, 2024 03:47 AM
Microtech
30
Apr 23, 2016 06:37 PM
RPOdesign
Aug 27, 2015 11:42 PM
