having a problem with my sparkplug diagram
Old Mar 22, 2004 | 11:53 PM
scrapp's Avatar
89GTUs (38k original mi)
i have a paragraph that tells me what spark plug wires go to what spark plugs( i have reason to belive mine have been switched), but it says on the coil packs it is marked as L1/L2-T1/T2 yet when i look all over, i see no such ****!
am i not looking hard enough? can someone give me some help?
Old Mar 23, 2004 | 12:08 AM
Icemark's Avatar
L1 and T1 are the front rotor,
L2 and T2 are the rear rotor.
with the front main (leading coil pack) you can mix them up and it will still work.
With the rear (trailing) coil pack, it's pretty easy... The front rotor (T1) is the front of the trailing coil pack, while the rear rotor (T2) gets the rear coil of the rear (trailing coil pack).
The engine is marked T and L for trailing and leading plugs (top and bottom respectivily) and the coil packs are marked with little 1/8 inch dia. white dots for the rear rotor spark plug wires.
Old Mar 23, 2004 | 12:10 AM
scrapp's Avatar
thanks. i knew about the housings being marked, and knew which coil packs were the leading and trailing packs, i just couldint find the marking on the coil packs.
Old Mar 23, 2004 | 12:40 AM
NZConvertible's Avatar
I'm a boost creep...
The letters are moulded into the plastic bodies of the coils, right by the connections.
succesfulljoe
Oct 5, 2015 10:18 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
