freeing up 5th and 6th ports...
Old Mar 22, 2004 | 06:19 PM
z4csl428's Avatar
From: Seymour, TN (couple miles west of the atlantic ocean)
im getting my 5th and 6th ports opened this friday, my friend said he had it done to his 7 and it felt like he was driving a different car. what kind of difference will i be looking at?
Old Mar 22, 2004 | 06:21 PM
BDoty311's Avatar
88 AE
Stock car? Probably around 15-20 hp gain in the upper rpms. Should be noticable. Try to make sure they are operating correctly, and not just going to be wired open.
Old Mar 22, 2004 | 06:42 PM
z4csl428's Avatar
yea its a 91 NA with 3" pipe from the headers, and 2.5" Y-pipe to dual apexi N1's, and an AEM cold air intake
Old Mar 22, 2004 | 06:56 PM
GEINN FC3S's Avatar
apex dual n1's u say? can u post a sound clip or a vid plz??
Old Mar 22, 2004 | 07:08 PM
z4csl428's Avatar
no, but they are loud and sound very nice especially since i have no catalytic converter or pre heater and am running 3" pipe
Old Mar 22, 2004 | 08:03 PM
Russ's Avatar
do you really get 15-20 in the upper rpms just from opening your 5/6th ports? how exactly do you do this
Old Mar 22, 2004 | 09:29 PM
tt1320flyer's Avatar
ya do tell!
Old Mar 23, 2004 | 08:47 AM
SureShot's Avatar
Seduced by the DARK SIDE
When they stick, it's usually just gummed up where the rod goes into the LIM.
Apply some penetrating oil & work it loose.
Pull the actuator if you need to (2 nuts, 2 screws).
Pull the LIM only as a last resort.
BTW - I have been giged on this also: You are not gaining 15 HP, you are recovering 15 lost HP..
Old Mar 23, 2004 | 09:43 AM
HAILERS's Avatar
HAILERS
Do you still have your airpump?
Old Mar 23, 2004 | 09:50 AM
hugues's Avatar
Why am I here ?
sounds like surgery ... hope all goes well.
Hugues -
Old Mar 23, 2004 | 10:13 AM
Kai's Avatar
Kai
Rotorphile.
Say what? AEM doesn't make an intake for our cars.
Old Mar 23, 2004 | 11:13 AM
SDrotary-FC's Avatar
@ pipnorcali
^^^ yea i have'nt seen a aem cold air for a fc
Old Mar 23, 2004 | 02:14 PM
z4csl428's Avatar
yea i still have my airpump why?
Old Mar 23, 2004 | 02:15 PM
z4csl428's Avatar
its an AEM cone
Old Mar 23, 2004 | 03:28 PM
dorifc3s's Avatar
BECAUSE YOU CAN USE THAT TO OPEN YOU 4TH AND 6TH PORTS.
Old Mar 23, 2004 | 04:14 PM
z4csl428's Avatar
how??
Old Mar 23, 2004 | 04:25 PM
Crionics's Avatar
s5 aux. ports run off of the airpump already. If they don't open, they just need broken loose. Try pushing the plunger down with your finger. If it is difficult, not smooth, or doesn't move at all, then you need to free them up.
Old Mar 23, 2004 | 04:38 PM
z4csl428's Avatar
well i live about an hour away from kevin landers who owns rotary ressurection, he was going to free up my ports for $200, is there any way i can do it and save a good amount of money?? also the plunger doesnt move at all when i try to push it down...
Old Mar 23, 2004 | 05:33 PM
Parastie's Avatar
Mountain Rotary Mod
I took mine off and soaked them in PB Blaster until i could blow into them and see them work.
edited for spelling.
Old Mar 23, 2004 | 05:34 PM
z4csl428's Avatar
and how do i do this?
Old Mar 23, 2004 | 05:38 PM
Parastie's Avatar
Mountain Rotary Mod
Well, i had my engine out at the time, but you should be able to do this with it still in the car. If you look on the passenger side of the engine, just above the exhaust manifold you should see the actuators for the 5th and 6th ports. They look a little like seals bowls with a rod coming out of the top. Try to move those rods, if they don't move then you need to spray the actuators with whatever solvent you have handy or like (PB blaster is my choice) after that you, you try to move them. If it doesn't work, spray repeat until they do.
If they will not move then i guess it's possible they're stuck inside the engine, then it might be better to have kevin look at them.
Old Mar 23, 2004 | 07:08 PM
z4csl428's Avatar
i worked with them for a while spraying WD-40 on the actuators and they didnt budge...
Old Mar 23, 2004 | 10:49 PM
Kai's Avatar
Kai
Rotorphile.
its an AEM cone
Not to nit-pick, but that's not an AEM CAI... just an AEM filter. AEM cold air intakes move the filter down to a place where they can actually get cold air, usually behind the right corner of the front bumper, impossible in an FC.
Old Mar 24, 2004 | 04:14 AM
GEINN FC3S's Avatar
whats the real names of these parts, ive looked into haynes manual cant seem to find aux ports and etc...
Old Mar 24, 2004 | 05:41 AM
mwpayne's Avatar
Admitted 'rexaholic'
I believe you're Wes's friend, right? On the ports, if the actuators themselves aren't turning the shafts, we might be able to free them up. Probably, though, it's the sleeves themselves that are stuck, and they're WAY inside the engine block. Kevin has to take the intake off to get to them, 3-4 hours work, that's why it's $200. BTW, that's CHEAP, Kevin is cheaper than anyone else.
If you'd like me to look at it to see if it's the actuators or not, feel free to bring it by, always cool to have another '7' in the driveway. On my new vert, one of my actuators was sticking, the other one, however, has stuck sleeves (job for Kevin). One works normally now, the other one I 'encouraged' open permanently.
We also MAY be able to tap them open and leave them that way for a while. It hurts your low end a little, but helps top end.
If you're having Kevin do the work friday anyway, just be patient and let him have at it, that's best
