Magic smoke
Old Mar 19, 2004 | 04:20 PM
comeonstart's Avatar
Magic smoke
When warming up the rx today. it was just about waremd up and i revved it to about 5k and then it started smokeing a blue smoke bad, really bad. then it went away a couple minutes later. what caused this?
Old Mar 19, 2004 | 04:26 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
leaking oil control seals. There are 2 rubber seals inside each side of each rotor that keep the pressurized oil from leaking past the side seals into the combustion chambers. When these get old, they get brittle, and eventually will allow the oil to flow past them at high rpm, high oil pressure conditions. Once oil gets past the oil control seals, the oil gets into the combustion chambers and is burned - hence the blue smoke.
If you only find that this happens with high engine rpm, then keep the rpm's down. Also note that if you can see smoke, you're burning about a quart of oil every 100-200 miles - so check your oil level more frequently...
My SE does the same thing after 175k miles and only on startup until the engine comes up to temperature. Once warmed up, the housings and rotors expand to help seal the rubber oil control seals better - resulting in no more smoking; unless I rev it up to 7k rpm, then SMOKESCREEN.
Only fix; rebuild.
Old Mar 19, 2004 | 08:15 PM
10,000's Avatar
gyeah, I got your magic smoke right chea an I'm passin' it to the left hand side
couldn't resist.
Old Mar 19, 2004 | 08:19 PM
K-Tune's Avatar
FD Daily
look at it this way..with all that oil in there, your housings will be VERY shiny on the inside when you take your engine apart
Old Mar 19, 2004 | 08:35 PM
mazdaverx713b's Avatar
Have RX-7, will restore
what are you planning to do??
Old Mar 19, 2004 | 08:37 PM
dirty86's Avatar
mine does the same
some day it will be fixed
ls1swap
Jun 3, 2024 03:25 PM
renjiv2
57
Jan 25, 2024 03:34 AM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
