Wiring help plz...
Old Mar 17, 2004 | 12:25 PM
Question Wiring help plz...
I just went single and I noticed I was charged a lot for wiring. According to my guy here, he had to take out all the extra wiring that went to the original twin turbo set-up, retrace it back to the PFC and remove it. Then he had to install my Defi Link guages (Oil P & TEMP, 2 EGT sensors - all of them linked) and he also installed the Blitz SBC-iD boost controller, and Power Meter. Also include any other stuff that needs to be done when going single that I may be unaware of. Take into account that my wiring harness was probably a lttile out of shape as well. He charged me for almost 4 1/2 days worth of work. Does that sound like too much???
Also, how much have you guys typically paid per hour for wiring? I don't want to accuse anybody before I get all the details, so any help would be much appreciated. Thanks everyone!
Old Mar 17, 2004 | 12:54 PM
$150FC's Avatar
Currently Winning
Doesn't the PFC use the stock harness?
I don't believe there's much actual wiring that goes to the twins. Can an FD guy confirm this?
Old Mar 17, 2004 | 01:50 PM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
He pulled the wiring all the way back to the ECU?!? WAAAAYYYYYYY overkill. Though, I wonder what the weight savings is on that?
Seriously, there's no wiring to the turbo assy. Just some vac. lines. All the wiring is under the UIM to the solenoids and some emissions things. I'm in the middle of a single conversion. Yes, there is a lot of crap that can go, but if done right, you just need to cut it back to the main loom; obviously making sure that the wires are properly isolated from everything else (shorts = bad).
I think he went above and beyond and sure as hell charged you for it though it wasn't necessary.
Old Mar 17, 2004 | 06:00 PM
Yeah I thought so. Now I have to go and see if he's trying to overkill me on anything else. Thx for the help boyz.
Old Mar 17, 2004 | 06:50 PM
Dwood432's Avatar
I removed all the unnecessary wires all the way back to the ecu, and it took me a couple of hours. The harness was also out of the car though.
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
